Project: Custom Coils
  • Project: Custom Coils
    Coilovers for the Protege are: meh. There expensive and to be honest, they dont go low enough. Thats why Ive designed these to go lower than any other Protege. I should be able to lay frame and still have strut travel. So here it goes. My progress...
    Been working and researching on this for about 3 months. With 16's in the front I had to dump my skunks practically all the way down which means im pretty much on the bump stops. You know what that means: horrible ride. So Iv come up with a design for a custom front coilover. Before you go all willy nilly saying "why don't you just buy coilovers already." For one reason, I have pretty much all the parts and tools i need, minus shocks. Another is I LOVE custom fabrication and that's what I'll be majoring in at Wyo-Tech next year. Here's my plan of attack...
    1. Ill be using my stock strut bodies as tubes to hold the new shocks. Best part is its free and i know it'll fit without a problem
    2. Shocks. These are what Iv been looking for over the past 2 months. Iv tried struts from other cars like; VW Rabbit, VW Golf (mk2 and 3), VW G60, BMW E30, Nissan S13 and MR2. Most fit well for the most part but I came to the conclusion that its not exactly cost effective. Not to mention the fact that these cars arnt very close to the protege's front weight. Then I started looking at oval track/modified type shocks and hit the gold mine. Shocks are available in almost every compression and rebound setting you could come up with. They also have a super short body and short stroke. For those of you who don't understand, it basically means the car is already lower while maintaining full strut travel. BILSTEIN is the brand Iv chosen, specifically the "big body" series with a 5/5 compression/rebound. This will give me a good balance of ride and performance with my 350lb springs. They have a 9" stroke, compressed length of 14.75", extended length of 23.50" and a 2.0" O.D. body. Iv measured the inside diameter and they will fit inside snug. Im going to chop off 2" of the stock mount tubes. From there ill be able to get the proper ride height while still remain the strut travel. One problem Is the fact that there is a bearing mount on the bottom of the shock. I think Iv found a solution in using a mount traditionally welded on to a control arm. Using this I can make a bracket that will wrap around the mount and let it sit flat up against the bottom of the strut tube. The shock will still be way to down in the tube so ill have to raise even more by having a spacer machined up.
    3. The endlink will need to be relocated, Havent decided if im going to keep it on the strut or some how mount it on the control arm.
    Parts have all been purchased, just waiting for them to arrive. Ill try and post pics up asap.
    Sounds good, but 370 is kinda low yes? if you are gonna run super aggressive offsets.
    -Instagram@jdjurhuus
    Stretchsaurus and Pokemon.
      It's what I have right now. There pretty damn stiff. I'll really have to see. Nobody runs crazy set ups on these cars. Right now I'm at 16x8 -5 with 195/40 tires. I'll try an get some pictures up asap.
        I love this shit, it's kinda what I had to do with my quantum. I used bilstein HD inserts for vw mk1, they're over an inch shorter. Only problem was that the bump stops were internal, so i had to disassmble them to cut them down. 450 fronts and 350 rear spring rates is what I went with. It's a little stiff, but I like that cause too soft isn't great when the body of the car is a 1" off the ground.
          sounds good dude. keeping my eyes on this. oh and good luck.
          PATCH WORKS UPHOLSTERY
            This is the kind of stuff I like to see in the build thread. Where people are doing what hasn't been done. No offense to other builds, but dropping are car and putting wheels on it is easy. Pushing the envelope of possibilties is not.
            I would like to see pics of all the steps you are taking.
            Gordo.
              great project. I wanna do the same thing, but I haven't looked into it at all yet. post as much information and pictures as you can. Hopefully you can save me some work
                look at my thread...the legend of one low cobalt. i did this. it worked great. just don't be surprised when you start having axles and misc drietrain parts start getting destroyed.
                  far as i can remember old (80-84) celica supra struts are short, as are the shocks, (i use them in the wagon, they last much longer than stock long strokes)
                  once your done name it the LOWtege'
                    Sounds like this is for a BJ?
                    I don't quite understand your mounting solution, but I'm eager to see this anyways. Being the lazy guy that I am, I just settle for off the shelve coilovers, but this has potential to be much better,
                    A better endlink location would be awesome too. The factory end-links suck.
                    Now I guess we'll just have to see if you can really go lower than any other Protege.
                      Yeah, its going on an 03. What dont you understand? the Inserts is simply siting inside the gutted stock struts.
                      BTW. This is my slab. The wheels are white now, but you get an idea. Gonna take out the front spacers and camber out the front and back. Then its as low as I can go....
                        ^like.
                          This part. Why not just cut off the mount and drop the shock in?
                          Also, what are you using for springs?
                            Car isn't in my taste :<
                            But subscribed so I can see you win this!
                              The struts have a bearing mount. Its not going to sit properly if you have all the weight on the top of the bearing. It'll cause the loop to deform and end up moving the whole assembly down. This will cause slack between the cap and strut. Slack is bad...
                              Springs are 6" 350lb Eibach's
