Originally posted by padraigmk3
View Post
btw, not sure if you've considered this or not but i dont think it would be too hard to get custom lower wishbones made so that you can adjust your camber. if you know a welder and can make a simple jig, you just need a few rod ends and some steel tube and plate (total cost under $200?? plus labour). normally you'd do the tops for something like this, but the bottom arms have bolt-on ball joints (tops are part of the wishbone) and by making bottom ones you can increase the track at the same time (which gives you your camber).
doooo itttttt, you know you want to.
or if you wanna do it quick n nasty, you could use the standard arms and reposition where the lower balljoints attach (plate it and then redrill the holes a bit further out)
