Originally posted by paul@brawlinpicturesView Post
He might notice after we post a video of AWD donuts
must fight urge to post video.
if it wasn't for how the rear suspension is setup for the r32 it would be easier to modify the car for awd. I swapped a vr6 into my cabby , after driving in the snow I wish I had awd. after looking at the bmw e28 535 rear end I think I may the easiest solution for awd in the rabbit.
on with the updates. the customer decided he was okay with going air to water intercooler with the space constraint issues we were going to run into. We would not have enough space to run a sufficient front mount intercooler and also radiator\ oil cooler at the same time
to build the intercooler we start with 14 gauge aluminum sheet metal
Then a bare intercooler core
end tanks welded on
just a quick shot of where the intercooler will be placed
Specializing in Volkswagen, Audi, and BMW service, performance & Fabrication in Charlotte North Carolina
ummm... the tank setup of that intercooler setup makes no sense.
please explain because i'm stumped on this.... is this some air-water setup that is shaped like flipped and over lapping "L" sort >>> L|7 where the main tanks are on the sides and the water has to flow up, around a 90* corner and into a very tight channel, down through the core into another tight channel around another sharp 90* corner and into the other side tank??? sorry for the poor representation but i'm sure you understand what i mean.
wont that cause an immense amount of restriction in the water flow and the effectiveness of the cooler in general?
i'd think more contoured channels that tapered down on the ends with larger tanks feeding them would be a much smarter design or is space really THAT limited?
Cheers
96 Lexus LS400 Airred out on Ordens
88 930 - 500+hp, canned on K18R's "the Porker"
00 V6 Focus - slammed on RS's "the V6Mistake" **SOLD**
by ZX3Tuning, on Flickr
