Damn, this turned out sexx....i think itd look better without the spoiler. Maybe if you threw on a deck lip....either way, like i said, sexx
Domestic Stance
So finally got the wheels done polishing. I spent a good 10hours per wheel polishing by hand. They look ten times better then they started, but there far from perfect.
Tires are 205/45/16 fallen ziex all around on 16x8.5/9.5 '84 corvette salad shooters z51 package.
1" wheel adapters, final et is 16x8.5 et 6.6 16x9.5 et12.6 sitting on hsd coilovers. Right now the front is maxxed out with all locking rings in place. Rear isn't done yet but planning on pulling the locking rings.
Still need to dial it in, get a drum brake rear trailing arm with custom caliper brackets to run camber, as the stock rear trailing arm can't be shimmed. Need to build a skid plate and raise the motor and tranny. I know a lot of people won't like this setup but I really do so far.
All comments good and bad are appreciated
Should have the new rear struts either today or tomorrow. The 16s are small but I'm at the ride height I want. The wheels only cost me $80, and adapters were only $190. So it was more of a trial fitment. Can't wait to get the back end down thou. It's so nice and low. I'm really happy with the height and the fitment so far. Just need to dial in the camber and I'm set
