Originally posted by White325is
View Post
My E30...
The metal has a thick layer of scale which doesn't allow it to rust. I moved away for college and don't have a grinder or anything to work on it with so I'm just going to leave it for a while. I have a friend who said he wants to make it a cowl hood so maybe I'll do that eventually lol. Would be weird looking.Wut?
Suspension wise I have Ground controls front and rear 650/750. Bilie sports in the rear, Koni adjustable in the front with the housings cut 3 inches. Ground control camber plates. IE 22/25 sway kit. All AKG bushings through out the whole car. IE rear camber kit. AKG upper shock mounts.Originally posted by hootie View PostWhat suspension are you running?
Need anything else?
Did you try putting some vinegar/water mix on it? Should rust up within the hour.Originally posted by jpod999 View PostThe metal has a thick layer of scale which doesn't allow it to rust. I moved away for college and don't have a grinder or anything to work on it with so I'm just going to leave it for a while. I have a friend who said he wants to make it a cowl hood so maybe I'll do that eventually lol. Would be weird looking.
And thanks fellas I appreciate it.
I hope it comes out good, Its a shit ton of work to do this. Some people dont realize that you need to strip all of the undercoating out of the wheels wells when you do this.
Then self etching primer, primer sealer, undercoating. Its a big pain in the ass but I hope it is worth it in the end.
I got to finish up my DD..
Why cant I leave anything alone.
Vinegar and hydrogen peroxide actually, doesn't do anything unless it rape it with a wire wheel. Shit is strong.Originally posted by White325is View Post
24v swap into the daily? You sir have a BMW sickness.Wut?
