soooooooo...
the super duper wide 200sx got sold... and i missed it,
the bmw got sold... to a judge... no joke..
and i wanted to get back into jap.. and you know me.. i love cars that are a little different
1989 Rx7 Fc3s Vert Turbo
its got 97k on the clock, and all in all is actually pretty clean considering its a 22 year old car, the normal small scuffs and 2 rips in the roof (in the place you get on any soft top car)
Specs are
Owned for 14 years by the previous bar one owner
Rebuild at 88k by WGT
Brand new 2 mile old BC racing Coilovers
weds kranze split rims 17x9 17x8 et8
Brand new tyres all round
8 Months MOT
3 Months Tax
Leather interior
Silicone hoses
Dump valve
Recent oil change
Cruise Control
Electric roof
Uprated speakers
Kenwood disk changer
Two amps (fuses disconnected as no head unit) professionally wired in
Heated rear screen
LSD
ONTOP of this all I got dual exit exhaust system for the car (bout a 3 or 4" slash cut tip on both sides, and all pipework and decat as well) and skirts + spats already colour coded to the car
so far only driven it 2x
electric roof works, all lights work and pop ups work, and leather is very very comfy.. and ride isnt crazy bumpy, tho it may be a tad low as the camber of my road makes the exhaust scrape LOL!!
PLANS are to either give it a massive tcut and polish OR spray it NATO GREEN, pending how i feel about it in a few days, raise it a few mm's and then do some roof repairs, either duct tape or look into new roof/proper stitch and patching, get some tests done on the engine (its been champagne tested in the last month?????? whatever that is)
and then skid it a bit.. as Its LOVELY to drive
ANYWAY a few pics for you..
and the extras i got
__________________________________________________ __________________
so today we and josh went out and patched the roof rips for a temp fix
then had a little look behind the rear seats
and found these
to which led to me discovering that the inside of the rood is lines with molehair
wooop
popped the bonnet open to check to see if anything had leaked overnight
found the amp wires
and then took some pics of the tops of the suspension struts and realised how mega clean they are for a 22 yr old car
and then took a few pics of the roof up so you guys can see how it looks
typical cannon pic whorage
x
ANYWAY!!!
what i did today
Tested the fitting of the Tannau Cover
THEN took the car for a drive, and after finding out i had 17mm clearence under it, raised the rear 15mm
check out the mega clean coillys
and then made sure the front no longer touched using the tape measure trick
took it for a test drive and got stuck behind these
and last but not least went out for a spin in jims sr20de Datsun.. its AMAZING, cant wait to get the sr20det into this
love it..
on the test run to kemals however stu performed a harsh brake to stop himself running into a car that randomly stopped, locked up and pulled a 90 degree flick on the motorway and managed to not hit anything, lucky lucky guy, however now has a lovely flat spot on his tyres - check the tread out
And then upon arriving at kemals en route to the seafront a metro burst into flames.. lol
fun times.. o yeah and we put some rims on ads's ps13
he can show you those
so whilst preparing for a interview today i got a knock on the door.. and this turned up
37kgs ... could only assume its my weldy
and then another van rocked up and delivered a boss for the fc... and then also have me a big parcel with
which lead to
and then swapped the DV over for josh's SSQV as a temp steal til he gets a 13
and found this amazing sticker on the passenger sun visor
so all in all.. an eventful day
HOWEVER!!! 1 small thing.. went to segensworth from pomps, after a good blast at 70mph on the motorway pulled onto the segensworth slip road leading to the roundabout and upon coming to a stop there was smoke coming from the underside of the car about the same place as the cat was from the underside, being in traffic i couldnt see this to be sure but it was coming from both sides of the car, no heat increase, no oil temp change or oil pressure change or water temp change, the lights changed colour and i pulled off and stopped round the corner and there was no smoke coming from under the car then, so im thinking maybe i do near new brakes on the car if they were infact smoking, if the fact there is a bit of wheel wobble at speed/the car hasnt been tracked since lowering it cause the wheels to smoke, or if where the heatshield 'came' off the cat the other day it was the centre section of the exhaust overheating from the prolonged heat from being sat at 5000rpm on the motorway for 20mins...
so the mystery is to be rekindled tomorrow.. as i will go get the tracking and wheels balanced, fit the decat, and then check all the discs and pads, as the rears are a lil low, but dont think its them causing the issue..
also ordered some DW internal drive wheel nuts as mine are pretty groggy ones and i feel like they are going to round every time i have removed them .. so they will also be here tomorrow
ALSO!!! thanks to ads and our lil halfords trip I now own a trolley jack, axel stands, and a slidey padded tray to lay on woop wooop
Just to add also got the new alarm going in with full microwave sensors and locking, and also got the stereo and amps sorted with a lil help from sextons
So expensive as fooooook day today but hey.. needs must
Clifford Alarm fitted to car by Dragon Audio and Security, great work and top bloke, have business cards if people need alarms fitted this is a CAT 1 alarm so insurance love it
Also with some help from ads and josh we test fitted the exuast system to the car (by test fitted I mean mesured up)
also got the bits from halfords to help working on it
Previous owner has managed to silicone in the centre caps, which was fun, had to cut them out
ALSO rear brakes 100% need changing, so have bought brembo's and some new rear pads
and to show that the car can be jacked without stilts
...and also fitted my DW internal drives
fun day
discs and pads being done tomorrow
however found a random pip that goes into the cat, looks like the air pump pipe according to the web, so not 100% on if i will decat til i find out how to go about this plug and pipe and if i can just block it or if it is important..
ANY rex owners would love tips on this
Find me one and it will go on, along with the SKIRTS and SPATS that came with the car
right so in my fragile state, i decided it was tim eto borrow a ramp and do the oil and gearbox and panel filter
thanks to Opie Oils for these
oil filter took literally 20 seconds to unscrew and change, seemed a little too easy if you ask me.. LOL
then emptied all the oil
and filled with fresh 10w40
then dumped out the gearbox oil, only took about 2 litres which was less than i thought as i thought the rex's took about 2.5 litres.. however the level checks out so???
Used the old Beer funnel trick to fill the gearbox oil with the 75w90 which when using the small hose took about 30mins for 200ml.. moved to the bigger tube from b+q.. (2quid for 2 meters, cheers then) and did the other 1800ml in bout 2 mins
winner
so yeah, gear changes are 98% less crunchy and smoother when cold and warm.. which is awesome,
now im off for some double xp cod for a few hours
still waiting for my 2 new front calipers to turn up and then will consider popping the weldy in
also need protyre in fareham to try and track the car as they are the only people i know of with a flat ramp in the portsmouth/fareham area??? anyone else know anywhere with a flat ramp and tracking abilities ??
also trying to get another s13 prefacelift splitter... and now i have
got a prefacelift.. and a facelift one.. depending on how low it goes.. although it does actually sit static on the floor...
that pic is an original from the last owner
o yeah and the 4 pots turned up
So took the car to Style and Slide workshop
Lads were great dan and nat cant thank you enough, and Lou thanks for lending me the wagon to get down there with the parts
1st thing, was to do the brake calipers for the siezed piston -
while nat was sorting that, stuck a cheeky 18" rim on for a test fit.. lol
and dan set to work on the zaust, 1st thing was to cut open the decat and empty all the crap out of it.. there was alot rattling around inside it
then weld the downsizer on and reseal it
and then build all the system up to make sure it would fit...which it almost did.. LOL
then with the joys of rotary engines having an air pip that goes into the cat so when the car starts cold it goes to 3000rpm for a few seconds and then back down to heat the cat.. but when removed can cause issues... so dan cut the old one off the cat and then drilled and welded it onto the decat, and then used his magic to adjust the whole system and make it fit
heres a comparison shot for you all
then drove it an hour and a bit to Brockham for an AMAZING bonfire and firework display, and then took it to the lads opposite for a cheeky clean
so today i woke up, went to move the car, and did the usual morning checks, and then found i had no coolant, rolled the car back and found i had def ost some water
luckily work let me have a half day so came hom at 1 and with the help of Adam got cracking on the car
rmeoved the undertray which was full of leaves and oil etc
aaaand it all turned out to be a cheeky little split hose that went into the side of the engine block.. which was a massive relief
so then we took the car out of wheelie mode and test fitted the side skirts
I LOVE them.. and they hide the rust lol
just need the splitter to turn up and its bodykit fun time
cannon out..
Car went in over the weekend for a professional clean and spruce
g3, g7, g10, boat wax, polish, and alot of treatment... and holy cow it came out well
the evening of picking up the car there was a 272heroes meet and popped down with some freshly fitted skirts to get a few pics and have a meet up
ANYWAY LADS AND LADIES!!
hope you like.. feel free to comment
splitter will be on soon by the way
I bought this car from a customer of mine who had the car for the last 14 years. When he first bought it he had the engine rebuilt by WGT racing, and a full body respray. Since his owner ship he has moved a couple of times and the history for the car seems to be scattered about. He just called me on Saturday to say his father found the old MOT's at his house and the tannoue cover for the roof was at his warehouse, which he is dropping off on Wednesday to me.
8 Months MOT
3 Months Tax
Leather interior
Silicone hoses
Dump valve
Recent oil change
Cruise Control
Electric roof
Uprated speakers
Heated rear screen
LSD
and found these
wooop
found the amp wires
x__________________________________________________ __________________
ANYWAY!!!
what i did today
love it..
which lead to
fun day
winner
cannon out..
the only thing i would do is seal all the bottom looks kinda rusty under there
