Alpine Green Pearlcoat is a pretty uncommon color for a Neon. It was also available on the Stratus and Caravan.
The plan was to run 10mm spacers all the way around, I got extended lugs for the front but not the rear. Finding a quality hub centric 10mm spacer wan't easy either. Having -0.5 degrees camber in the rear would have put the rear tires right into the fender without rolling them. The front was set at -1.5 so all is fine and dandy up there.
I'll have pictures of the Miata later today.
