setting autopilot preset ride height
  • setting autopilot preset ride height
    Hello,
    Wondering if anyone can help direct me to how i preset the ride height that i want for the middle button on the Easy street autopilot.
    Thanks in advance.
    2007 Porsche Cayman S
    UNDER CONSTRUCTION
    Originally posted by tayTay View Post
    Hello,
    Thanks in advance.
    "taytay"
    what problems are you having. make sure you. . .
    Have calibrated the ECU 1st
    Have atleast 135psi in the tank
    If all that is done, put the car on all 4 corners of where you would like the car to ride. Hold the middle preset until "Ride height" pops up. Then put her down and just tap the middle button again.
    Hope that helps
    SteveO@OpenRoadTuning.com
    (888) 407-2997
    >>>OPENROADTUNING<<<
    >> CHECK OUT OUR NEW WEB STORE!! <<
    Become a Fan!!
    Homegrown Motorsports
    Blown Euros
    Wheel Whores
      Are you using Easystreet valve blocks or other ones like Asco? Only the Easystreet valves will allow you to use the auto-ride height function correctly. Other valves are a toss-up and generally don't work. In my car the front auto-sets correctly but the rear doesn't do anything
      Flickr
      Originally posted by Kielan
        i have the easystreet valve blocks. Thanks steve! I'll try that and report back.
        UNDER CONSTRUCTION
          Any Luck?!
          (888) 407-2997
          >>>OPENROADTUNING<<<
          Become a Fan!!
          Blown Euros
          Wheel Whores
