Results 1 to 4 of 4
Thread: My EG9 stance project. Question
    Default My EG9 stance project. Question
    I'm using a coilspring and stock shock after making it low ride is so bouncy.
    any solution or ideas?
    thanks
    coil springs or coil over sleeves?
    if they are coil over sleeves and you cranked them down low then the struts probably got blown out if they weren't blown out before.
    get some decent short struts and extended top hats
    Coil over sleeve only.
    Better go to a store and get it homedepot survey bluestacks fixed.
