Page 1 of 6 123 ... LastLast
Results 1 to 25 of 129
Thread: Rusty Slammington v2.0
    Mar 2009
    Nashvegas, TN
    4,202
    Default Rusty Slammington v2.0
    Well, here goes nothing! This is going to take a long time to put together, so have some patience
    First things first, if you somehow missed it, here's my last built thread:
    http://www.stanceworks.com/forums/sh...ad.php?t=10970
    Most of the pics are dead at this point, so I'll need to go in and do some maintenance and re-host everything.
    Anyway, onto the good stuff. It feels most fitting to begin with the fire.
    In April of 2011, my garage caught fire with my car inside, and everything inside was burnt to varying degrees.
    The fire was started as I was attempting to build a wiring harness for an M30. Not knowing what I was doing, I managed to fill one of the cylinders with fuel, and in order to purge it, I pulled the spark plug and spun the starter in order to shove the fuel out of the cylinder. Something sparked, and the rest was history.
    For a few hours, I figured that was the end of the car, but before going to bed the night of the fire, I knew the car would come back. It had to. After some deliberating with my friend Chuck Yoder, we talked about the possibility of rebuilding it. The chassis was tweaked and twisted, unfit for road use, so we knew it would take drastic changes. Chuck convinced me to go full tilt with a tube chassis, as opposed to building a serious cage to support the original structure. At the time, it was something far beyond my skill set, and in retrospect, I really had no business doing what I was doing. Nonetheless, I was eager and bright-eyed, so we jumped straight to business by cutting the car apart.
    May, 2011
    Knowing that the car was going to get cut to bits anyway, I suggested the idea that we convert the car to a coupe. I did a couple of photo shops to see if I liked the look. I began with a pretty simple version: simply shortening the car, and molding the back doors into the body,
    But that made for some really stumpy front doors, so I moved the B-pillar back and lengthened the doors:
    That started to look more like the coupe I was envisioning. I did one other chop I've managed to find since then:
    So, with a plan, we got to work. As we were cutting, we braced the insides of the car up, knowing we'd have to cut the car in half in order to shorten it.
    We didn't want to wind up with two loose halves of a car, even though we weren't interested in making it perfect, so we created a sort of "slider" out of angle iron, so that when the car was cut in half, we could slide the front to the rear and reconnect them without too much effort.
    In the photo above you can see the slider taking shape, and how it was intended to work. Wed be able to cut everything out between the two vertical rails, and the car would still be "connected" in a sense.
    From there, we got to cutting!
    It was quite scary making the final cuts and seeing the car in this state. It was definitely the point of no return. We slid the halves together, and as you can see, everything actually lined up pretty well, luckily for us.
    From there, I cut down the doors to begin the rest of the conversion:
    Here's the fit, prior. Obviously they don't fit anymore.
    We stuck the B-pillar back in, 6 inches further back ,and then attached the tail end of the door to it, so we could get an idea of how to extend it. We chopped up the rear doors in order to give us the material.
    And here it is with the extension in:
    From there, we continued cutting the car apart:
    Here's one of my favorite photos of the build, and it was one that was very hard for me to not share. Cory actually snapped it during a visit to Chuck's, as I was cutting in the background.
    In and amongst the chopping, we stuck the remainder of the rear door to the body:
    However, inside was beginning to look more and more barren:
    If it wasn't obvious, it was the messiest automotive endeavor I've ever undertaken. It smelled awful, was a huge mess, and was rather arduous.
    Eventually, I got the whole floor cut out.
    We continued throughout the summer, and over time, I finally cut away nearly every bit of interior metal, leaving only the car's skin. I had begun to acquire parts for the actual build of the car. We worked on a lot of other aspects, some of which I may go back and cover, but in the end, progress halted.
    I moved to California in November of 2011, leaving the car behind to sit in Chuck's yard under a tarp. In the mean time, I built an E9, and then built the hot rod as an exercise in fabrication. Leaving chuck behind meant I was all on my own.
    April 1, 2014
    I trucked the car out along with Jeremy Whittle as he moved to the west coast, but it sat for a good while as I prepared to work on it.
    Byron had joined in on the hot rod project during its second half, lending an invaluable hand in getting it complete in 2013. I had told him what I wanted to accomplish with Rusty, and he was as excited as ever. What was complete already only scratched the surface. When the time came, we pulled the tarp off of rusty, and got to work. April 1, 2014 was our first day working on the car after a several-year hiatus.
    Oct 2010
    SoCal
    10,811
    And so it begins ...
    I dislike Byron.
    Feb 2010
    Brooklyn, NY
    40,596
    <3
    - Kielan (Key-lin)
    It came out great man. A long way since I last saw it in Chucks garage
    Jul 2010
    Manchester, U.K
    1,045
    Looking forward to the rest of the build photos.
    Quote Originally Posted by MommysLittleMonster View Post
    Internet high five for you.
    Mar 2009
    Nashvegas, TN
    4,202
    Working on the second step now! I know a few people saw the partial chassis we did at Chuck's place, but upon arriving in CA, we scrapped it all and started over (which I hope is obvious)
    Jun 2010
    windsor, ont
    172
    Good read so far
    Jul 2009
    Bay Area, CA
    12,330
    Looking forward to the tube chassis creation.
    Quote Originally Posted by Oxer View Post
    Quote Originally Posted by Average_Jerk View Post
  9. #9
    Aug 2010
    connecticut
    1,524
    Thanks for writing this up!
  10. #10
    Jul 2013
    Bellevue, WA
    455
    Congrats on everything, can't wait to see more of this build!
    @projects_always
  11. #11
    Mar 2015
    Sydney, Australia
    379
    so beautiful!!!
    every part of this car is amazing, i love all the fab work Mike!!!!
    Rusty is a beautiful monster!!!
    resurrected from the dead
    talk about built from the ground up !!!
  12. #12
    Quote Originally Posted by M.Burroughs View Post
    Yea man, you can definitely see that
  13. #13
    Mar 2009
    Nashvegas, TN
    4,202
    April 2, 2014
    So, after several years of not working on the car, and having learned quite a bit, I, along with Byron, was ready to tackle what seemed like an impossible project: building a car from scratch.
    If you look closely, you might notice that before bringing the car to California, we had cut and widened the rear fenders 2" - this was, at the time, a "wide body" and was the direction I was thinking of. The IMSA inspired side of the project surfaced in the interim, as I found my automotive passions.
    For years, one of my favorite cars has been Porsche's 935 K3, which served as a huge inspiration moving forward in 2014.
    The K3 introduced me to the Zakspeed Ford Capri, which probably currently stands as my favorite car.
    It's cousin, the Zakspeed Mustang:
    And of course, some inspiration from the BMW camp:
    Obviously, there's a recurring theme. If you've seen the completed car, you hopefully see the sources of inspiration behind it. Everything from the boxed fenders, low rooflines, bodylines, wild aero, and especially the wheels. The 16/19 stagger is, in my eyes, a quintessential part of the Group 5 era, and so while the car was in Tennessee, I began collecting parts and pieces.
    The wheels were the first piece of the new project. In 2012, I had purchased the centers, and from there, moved forward in collecting the halves, which took some time. I wish I had pictures of the process, but if I did, it wouldn't be very exciting anyways, because it's just wheel pieces.
    The centers themselves are off the Brun Motorsports 956 Jagermeister car, and still have their BRUN stampings on lug sections of the wheels.
    The rim halves, however, were collected separately, and are presumably off of a Porsche 935. The fronts, in the end, measure out to 16x12 and the rears are 19x14.5 in original spec.
    With the wheels in hand and ready for the project's start in April 2014, I knew what I wanted to accomplish with the car. I wanted to build a Group 5 tribute. I had andrew sketch out to the best I could explain it to him, and this was the drawing I had to work with for the rest of the build:
    My friend Roland at H&R Suspension has been a long-time fan of the car, and when I showed him my ideas, he was interested in partnering up on the car. I knew it wouldn't be possible without some help from some great minds, and Roland made sure we had what we needed to accomplish our goals.
  14. #14
    Mar 2009
    Nashvegas, TN
    4,202
    I'm off to a photo shoot, so the next bit comes (hopefully) tomorrow!
  15. #15
    Mar 2014
    London
    1,120
    I am witnessing Stance Works history, this is oh so exciting.
    The original sketch of the car gave me goosebumps, theres just something very very special about Rusty
  16. #16
    Sep 2014
    sydney
    258
    FUCK
    why did you have to post this now
    I have an eng final in 3 hours
    dammit i'm reading it
  17. #17
    Jan 2012
    Los Angeles
    6,008
    Welcome back kind sir.
    IG: @sebastienaudeon
    1974 Porsche 911S
    Quote Originally Posted by TRaNz View Post
    *pats Sebs head*
    there there.
  18. #18
    Aug 2013
    Waikato, New Zealand
    70
    Great read so far Mike, Looking forward to the rest of the post!
  19. #19
    Jul 2014
    Berea, KY
    852
    It's great to see you posting again, Mike! This thread is incedible already.
  20. #20
    Jun 2015
    Québec, Canada
    274
    oh yes. I'm eager to read through all the build!
    Ruining cars since 2006 yo
  21. #21
    Mar 2015
    Sydney, Australia
    379
    ahhh this build gets better and better !!!
  22. #22
    Dec 2013
    Chicago
    137
    Massive respect, really love the direction rusty has taken!
  23. #23
    Nov 2011
    Clarksville, TN
    225
    As most, I am a huge fan of seeing Rusty's reveal at SEMA as well as the build from the previous era.
    It was one of the few cars that pushed me to sell my old truck and start new, continuously trying to break a stereotypical mold.
    Happy to see another chapter.
  24. #24
    Aug 2009
    MEL Australia
    23,230
    I still remember the afternoon spent at chucks, I felt like a little school kid, all giddy with excitement.
    That was such a memorable trip. Remember the first night in TN?
    Quote Originally Posted by anth View Post
  25. #25
    May 2011
    Michigan
    1,399
    Sweet baby Jesus. Subbed for more.
    lamborfuckinghini
