use some aircraft stripper and a coarse steel wool pad. should make it easy. just wear a glove as the stripper burns the skin
polishing wheels
1982 euro porsche 930 turbo
Wow, that Tal-Stripper or most any stripper in gel form is superior to all my experiences.
I put that on paint, let it sit, maybe scrubbed a bit with a green scotch bright, and then rinsed it off with a hose and it was clean as a whistle bare metal.
You can smear it on thick and put it in a garbage bag. Something about the way it heats up that way. People have said you could use saran wrap also. Never tried that.
i am! so i tried the gel stuff on my friends wheels im painting for him and his paint came off. are bmw wheels powdercoated is that why its so hard? i got somewhere today though i just used a scrapper and scraped off some paint haha and got down to some primer.
You should invest in a soda blaster...It makes it wayyyy easier. You need to use a lot of paint stripper and let it heat up in the sun. Watch your hands because it burns like a bitch...
how long are you leaving the aircraft remover on the wheels for? are you really globbing it on? i used the aircraft remover from autozone on my porsche wheels and it sat for a while but the clearcoat/paint finally came off.
also, how bad is the rash? how are you planning to fix it? if you are going to fill it at all with anything that isnt metal (body filler, polyester filler) you wont be able to polish the wheels.
post up a pic, youll probably get more help that way.cammed, slammed, & female driven
only 1 wheel has rash that ill sand down not to worried about that. i just put a crap load of the stripper and left it in my garage like 2 hours ago did go back to check on it. but hopefully it does something. If not i have no other option to let rotiform polish them for me haha.
If the wheel is powder coated, you will have one heck of a time removing it with store bought stripper. Your best bet is to let a powder coating and or stripping company strip your wheel with industrial stripper. DO NOT let them sand blast your wheel, if you want to have them polished (or polish them yourself).
Originally posted by gtrefever View Postthats what i want to know, are stock 745i wheels powdercoated from the factory?
