Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: OM602 diesel swap over
    Sep 2011
    Northern VA
    312
    Default OM602 diesel swap over
    So...I started a thread at mbca.org, but decided to just make it here as well. A quick history is I bought this 1987 190D 2.5 turbo with abou 78k miles on it, but the body was rusted pretty bad. I started cutting out alot and welding on the rockers, interior, etc. When i went to start repairs on the driver side rear is when i noticed how bad it was, the body wasnt even worth saving. Rot through the front frame under the batter, no more floor under the rear seat, the rust was creaping up to the rear sub frame and the trunk was just F'ed.
    Long story short, I bought a 93 190E 2.3 body with no rust and am going to town bring the diesel over to it. Luckily its also black with the same color interior....but the front end is entirely different since it a 4 cylinder. So here comes the photo dump:
    motor out of the donor:
    the core support from the gasser 4 banger:
    the core support from the diesel:
    spot welds removed from gasser core support:
    wiring harness removed:
    Diff out of the 190e
    Diesel moved in for the dissemble:
    not happy to have these guys sit outside during this:
    Sep 2011
    Northern VA
    312
    Diesel dash disassembled and labeled:
    Diesel OM602 drive train coming out:
    Diesel fuel plumbing removed along with oil cooler:
    Diesel fuel tank needs to be carried over as well:
    Diesel diff, in need of alot of cleaning....
    Since the brake like for the Pass front is diff on the diesel than the gasser [gasser line gets in the way of the turbo], i had to transfer it over:
    again, since the bumper bar, and lower radiator support is totally different on the diesel, i had to cut out alot of shit, this is from the diesel:
    all cut out of the gasser:
    ready to weld into place:
    done:
    Jun 2015
    Québec, Canada
    274
    impressive work so far! Diesel ftw!!
    Ruining cars since 2006 yo
    This is a really wicked swap!
    - Renato
    TWMPerformance.com | TWMShiftKnobs.com | GodSaveTheManuals.com
    Sep 2011
    Northern VA
    312
    thanks guys, the amount I spent for the actual car and the donor car is probably close to about the worth of the motor, so I didnt mind spending the money on the rust bucket knowing that it would probably have to end up coming to this. The only thing that sucks is that this rare to the US car, will no longer be originally rare being that its getting a complete transfer.
    etched and seam sealed:
    based:
    cleared:
    radiator support, horn bracket, and body bracket all covered with that doo doo rubberized coating and based/cleared
    Mar 2013
    Oshawa, ON
    52
    Damn this is one helluva swap, keep at it
    Never argue with an idiot. He'll drag you down to his level, then beat you with experience.
    Mar 2010
    Portland, OR
    684
    OM602s are so rad. Will it be getting a 5 speed?
    IG: ossiep
    Sep 2011
    Northern VA
    312
    nah, no 5 speed, this is just my daily, just need it to run and look semi decent, i got like 7 other cars to play with :P
    Im prolly going to pull my AMG's off my other white 190 and use them on this, Ive got some progressive rate 500E H+R springs that ive had for 13 years that will fit on this, prolly just cut some coils.
  9. #9
    Sep 2011
    Northern VA
    312
    got the wiring harnesses out and transferred over, just need to finish the wiring for the trans and gut the shell, then on to the motor:
    Cruise control wiring...since the previous owner cut the plug instead of unplugging...
    Dug up my 4 pots that ive been hoarding, I think I will finally end up using these on this:
  10. #10
    Jul 2013
    Pennsburg, PA
    168
    Save the diesels! I drooled over your '72, and your quality of work is top notch. Subbed.
  11. #11
    Sep 2011
    Northern VA
    312
    Quote Originally Posted by speakerboy View Post
    Thanks!!
    I have completed the disassembly of the diesel shell, most everything needed is out, including the springs, brakes, etc [since i like to hoard :P ]. I was finally able to push out the shell from the garage in the move the engine into the garage to start maintenance, especially on items that would be harder to do with it in the car, I.E. lower oil pan.
    Currently the to-do's are clean up all the turbo piping and new seals, exhaust manifold, intake manifold, diesel injector heat heat sheilds, power steering pump rebuild, valve cover gasket, oil pan seals, trans cooling lines, flex discs, etc.
    When taking the manifold off the motor, the first stud snapped in half...so I will be redrilling that
  12. #12
    Sep 2011
    Northern VA
    312
    last night was just more cleaning, refreshing of surfaces. I removed the oil filter housing, as I am trying to also track down the notorious mystery leak on these om60X motors. Cleaned up the filter housing and have ordered a new seal for this:
    Heres a nice close up of the stud that split when removing...of course it conveniently broke in the head.
    After digging around, i found that some members were looking at possible leaking through the water pump bolts near the bottom, will have to check that, however I also read that some guys in the MB forums were seeing excessive leaking out of the timing tensioner seal to the motor. I took a look at mine, and yeah, its pretty wet, I havent had a chance to see if its still within torque value [70-80nm], will have to try that tonight. I am hoping this is pretty much the suspect as i do have a good amount of oil coming from behind the alternator bracket area, which is also present on the AC compressor side. I did also notice that the little 2mm breather hole on the valve cover is completely blocked. Once i remove the valve cover, I'll let it soak in my parts cleaner and give it a good scrub down.
    Other that that, I am debating if I should rebuild the turbo while its out, since it is near impossible to remove once back in the car, what are you guys thoughts? The motor has around 88k on it as of right now. There seems to be the bit of black build up between the cold and hot side of the turbo, from what i can understand is normal? or could be attributed to improper crankcase ventilation. The turbo worked great before i pulled the motor, dont have any idea regarding boost.
  13. #13
    Jul 2013
    Pennsburg, PA
    168
    Quote Originally Posted by lewda View Post
    How much is the rebuild kit, vs. the pain of doing it once the car is back together? Is there room in the project for this, or are you trying to resist budget creep? Honestly, I would see if there is shaft play, and if not, clean it and slap it back on - especially if you aren't turning it up.
  14. #14
    Sep 2011
    Northern VA
    312
    By shaft play I'm assuming you mean the impeller moving in and out of the turbo itself? There's none, spins free as a bird both hot and cold ends. Turbos are for sure my weak spot, I am definitely no expert, working on the turbo once in the car is near impossible. Budget is somewhat a factor, but more time, the rebuild kit is cheap, around 60 bucks....I know she spoils and she delivers the power, I'm assuming my exhaust grime from the cold to hot is more due to the clogged crank ventilation? But again, lack of knowledge on that dept. all in all, I want to rid as much as possible the notorious diese oil leaks
  15. #15
    Sep 2011
    Northern VA
    312
    So I heckled the turbo again, the cold side has a tiny bit of left and right play of you will, the hot side has zero
  16. #16
    Sep 2011
    Northern VA
    312
    had a late night jam session on the car to get things done so i can focus on the injectors and intake manifold this weekend. Was able to get the Oil pan, and smaller pan section [no idea for the formal name on this] seals replaced and parts cleaned, did the valve cover seal and grommet and cleaned up the cover, and rebuilt the power steering pump. Was amazed at how easy the pump was to rebuild.
    I think I am just going to break down and rebuild the turbo since they are near impossible to remove once in the car. The only things I should have left on the engine maintenance is the turbo, the injectors, intake and exhaust mani seals and I should be ready to put her in the car.
  17. #17
    Sep 2011
    Northern VA
    312
    so, the build isnt dead, just been super busy with work and have been gone some weekends. This weekend was prolly the biggest push in regards of progress. I rebuilt one CV joint that had a crack in it, this will hold me over until I buy new ones. Got the motor back in, I would have to say the biggest pain was just putting the oil cooler back in.
    So, upon putting the motor in, and adjusting some things, I realized that the stock shocks are blown, another thing to add to the list. I also dont like how high the front end ended up sitting, which surprised me considering the springs are for the four cylinder that used to live here. I have some progressive rate H+R springs for a 500E that i have been saving forever that I think I will end up using on this to help bring it down a bit.
    The only thing left is to connect the trans cooling lines, top the trans off, differential fluid, radiator fluid, put some diesel in and hope all is well, haha.
    Top
  18. #18
    Sep 2011
    Northern VA
    312
    success, got it fired up, currently with no down pipe from the turbo or air box, now I just need to straighten out the glow plug warm up light.
    https://youtu.be/xzMADVzZhvU
  19. #19
    Sep 2011
    Northern VA
    312
    So nothing interesting has really happened recently, went to the beach:
    Currently I have just been putting the interior back together and cleaning everything, checking wiring in the cabin, etc. I found the progressive rate E500 springs that ive been hoarding for about 13 years that I am finally using, haha :-P
    some more pictures for the lulz
    The E500 springs are in with 1 coil cut, which pretty much put it at stock ride height, think im going to cut one more.
  20. #20
    Sep 2011
    Northern VA
    312
    This weekend I went ahead and painted all the cladding, skirts, bumpers and blacked out the grill
    I redyed the impact strips
    pin stripping erased
    blacked out grill
    threw on some AMG's, needs to be lowered
  21. #21
    Sep 2011
    Northern VA
    312
    getting closer and closer, finally got 98% of the interior back in, buttoned up the fuse box and such. Confirmed that my CV joint is bound, so I will need to take that back apart and see if i cant fix it.
    Pics for your enjoyment.
  22. #22
    top notch!
    Hipstagram tberardinucci
  23. #23
    Sep 2011
    Northern VA
    312
    well I was able tonight to figure out very fast after removing the CV joint from the car, that i put the joint together at the Diff backwards....SMH....was an easy fix however, thankfully I was able to fix this before I attempted to drive it anywhere. Also went ahead and "adjusted" the suspension so to speak to a more attractive height.
    fixing the CV joint:
    Car is lowered! No its not slammed, however much so I would like to have it as so, but I am going to be driving this car roughly 120 miles a day, so this is a perfect height
  24. #24
    Sep 2011
    Northern VA
    312
  25. #25
    Sep 2011
    Northern VA
    312
    last nights tasks were to buff out the paint on the roof, trunk and hood that was in such poor shape. they all needed to be wet sanded and buffed as the single stage paint had pin marks all over it from sitting for so long and never being washed:
    Heres a little transformation from the day I picked up the shell, to now
