Get hub adapter spacers, that's what I did. They bolt to your hubs using your stock studs, then you bolt your wheel to the studs that are set into the spacer itself. No extended lugs required and they come in 15mm all the way up to whatever 3 inches is in millimeters.
My FG1!
Originally posted by Spectra Phantom View PostWelcome to S|W bro. Nice civic, cobra wheels look good
Originally posted by Dremetos View PostGet hub adapter spacers, that's what I did. They bolt to your hubs using your stock studs, then you bolt your wheel to the studs that are set into the spacer itself. No extended lugs required and they come in 15mm all the way up to whatever 3 inches is in millimeters.
Originally posted by Dremetos View PostYou can run 5mm without extended studs. If auto part stores sell them, they're safe to run. They won't risk a law suite like that.
Well I did some very rough measurements of my tire to fender clearance and I came up with somewhere around 20-25mm....somehow that doesn't seem right considering I'm running 17x9 +24 already... So if this is the case I would get some 15mm bolt on spacers. If anyone would care to chime in here's a picture of the gap for reference:
Originally posted by puzzlemaster94 View PostI love these color 8th Gens. Never knew Cobra's would look good on these
Originally posted by E.Myers View PostI don't think 15mm spacers will clear the stock studs.. Atleast they didn't on my accord
You don't think 15 will clear though?
Originally posted by E.Myers View PostNah. The stock studs will stick out past the spacer. I think 20mm is the smallest spacer of that type that you can run.
Trying on 25mm spacers in the front this weekend and I'm debating on whether or not I should try the rear too.
Originally posted by jerrychoochoo View PostI dig it.. HFP lip kit all around would set it off.
