Page 1 of 35 12311 ... LastLast
Results 1 to 25 of 856
Thread: Groundhog Day ... Yep, another 911
    May 2011
    Michigan
    1,409
    Some of you may remember my last 911, a daily driver:
    Full build:
    http://996ls1.blogspot.com/
    Acquired, 2000 Porsche 911 with the same wheels as my last did (996.1 GT3 ), HIDs, terrible hifi system, sun/moon roof and heated/power seats. Luckily the car is missing some of the heavier options.
    Last edited by white out; 07-17-2015 at 12:40 PM. Reason: Groundhog Day ... Yep, another 911
    May 2011
    Michigan
    1,409
    Like I said above, I picked up the 911 and then jumped on a plane to travel for the holidays. This left me with a computer and some extra time. Of course it resulted in purchasing parts.
    Standard parts: new light bulbs for the entire exterior, wiper blades and cabin filter.
    This is what I was working with: the 911 was fairly quiet with the stock exhaust, 911's carry all the weight in the back and Porsche aftermarket exhausts are expensive. I started hunting and found myself a used cat & muffler delete. This should fix the subtle exhaust note, drop weight from the factory exhaust and associated heat shields, and was not expensive.
    While the Porsche Sport Design wheels (aka GT3 wheels) were pretty sweet. I'm a big fan of 996 widebody wheels. This is a big no-no in the Porsche community because the wheel's offset pushes the edge beyond the body of the car. However, a set of coilovers with some dialing in fixes this issue and the tires will tuck under the fender. So I went ahead and picked up a set of turbo wheels with good PS2's.
    May 2011
    Michigan
    1,409
    Even though the turbo wheels would look like crap on the stock suspension. I decided to install them. Immediately after pulling a wheel off the car I realized something odd. . .
    The car already has H&R coilovers, which were not disclosed to me. Oh yes!
    Onto the wheels.
    Before:
    After:
    I have done zero adjustments to the suspension and need to adjust the car down for proper fit. But here is how the car sits, not too shabby.
    oh dick
    2009 Volkswagen Rabbit 2.5L "Snowbunny"
    1987 Volvo 244DL M47 "Turd Ferguson"
    1974 Volkswagen SuperBeetle 1303 "Diego"
    Jul 2014
    Lone Star State
    1,421
    I dug your vette. But im loving the porsche back in the daily duty seat. What are you plans for it? Just low/ wide?
    Also how does the 640 drive? It looks like an absolute blast....that was probably a stupid question.
    EDIT: Now im on youtube watching 640 exhaust videos and im in love.
    May 2011
    Michigan
    1,409
    Quote Originally Posted by mikey G View Post
    Porsche plans are just subtle things; the above posts (which weren't up when you posted), along with misc updates to it. It's so much more comfortable than the Corvette and pulls a wheelie on my way into work.
    LP drives totally different than the early Murci (which I've had prior). It's much more refined, significantly quicker, the carbon brakes take some getting used to, front scrapes more easily, otherwise it's the same car. I do need to get to converting it to 2WD.
    Here's my favorite video, I need to get to work on the Lambo.
    https://www.youtube.com/watch?v=p4Uw1knt1C4
    Jul 2014
    Lone Star State
    1,421
    Awesome man. I've always wondered myself if, given the situation, I would buy a supercar or just build my dream car. Cool cars man, stay humble.
    May 2011
    Michigan
    1,409
    Changed the intro to keep this thing on track.
    Forgot to mention that while this is the slowest car I've owned in the past 5 years, it's still a great place to be for a DD.
    A better view of current rear fit:
  9. #9
    Weird how the turbo wheels don't really poke that much
    In for more updates on this.
    Simple c2?
  10. #10
    May 2011
    Michigan
    1,409
    Simple C2.
    It's lowered a bit, so the turbo wheels sit more flush than at stock height.
  11. #11
    May 2011
    Michigan
    1,409
    little update.
    removed the clutch pedal helper spring, this makes clutch engagement MUCH easier. While the pedal is now 1000000000000x heavier, it is no longer vague and makes driving more enjoyable.
    15mm H&R spacers with some longer wheel bolts on the front. Makes the car look much better since the rears sit flush with the top of the fender. Turn in is a even better now.
    before:
    after:
  12. #12
    Looking clean. Did you out exhaust delete on already?
  13. #13
    May 2011
    Michigan
    1,409
    I have the exhaust, just haven't installed it. Trying to get as much done as possible to the Porsche now, but the other cars are begging for attention.
    Tonight I installed the AUX input cable. While this doesn't look as clean as the install I did on the last car, with the iPhone5s plug at the bottom of the phone, it is more user friendly. Also, the plug tucks neatly into the crevice.
    Today I ordered:
    hardened engine mounts
    hood struts
    wheel center caps
    smooth air intake hose
  14. #14
    May 2011
    Michigan
    1,409
    Installed the smooth air intake hose today. Based upon other owners' reviews that the car makes more power, better throttle response, a nice intake sound, etc. Did the quick install and . . . absolutely nothing. I cannot tell any difference in drivability or sound. But I guess it looks baller, even though it's dirty.
    I took a picture. lol
  15. #15
    Maybe because they have a cone filter?
  16. #16
    May 2011
    Michigan
    1,409
    Nope. Literally the same thing.
  17. #17
    Nov 2011
    SoCal
    2,449
    Wow, another great build
  18. #18
    Feb 2014
    boise idaho
    69
    Lambo, Lotus, and a Porsche!!! Jesus, 3 of my all time favorites! (especially the SV)
  19. #19
    Oct 2009
    SoCal - I.E.
    1,052
    yup. im going to be watching this. im pretty damn sure this will be good.
  20. #20
    May 2011
    Michigan
    1,409
    nothing major here, semi solid motor mounts and some new wheel center caps
    no more of this
    Rear needs to come down just a pinch to tuck the top of the rears a bit more.
  21. #21
    Mar 2013
    Rhode Island
    1,050
    well i'm pretty jelly right now.
    This is my signature
  22. #22
    May 2011
    Michigan
    1,409
    Center caps make a big difference
  23. #23
    Looks cool
  24. #24
    Nov 2013
    Big Rapids, MI
    98
    This should be good. I remember back in the Xceed days.... Subbed!
  25. #25
    May 2011
    Michigan
    1,409
    *alarm buzzing*
    It's a whole new day and 296bhp really wasn't cutting it.
    So I bought this.
    Lotsa' omlets in this pic.
    Yes folks, a GTfaux and it needs some work. So stay tuned.
