Results 1 to 19 of 19
Thread: Raising engine? E36
    May 2011
    Norfolk, UK.
    171
    Default Raising engine? E36
    Ladies and gentlemen, does anyone know the maximum lift I can do on my e36 (m52 fitted to 318is) without causing issues with the prop angle etc? Has anyone done it? I've had people say from 20mm -25mm..
    I've made some risers up @25mm that I can shorten if needs be, just trying to find some info before I fit them!
    I'm trying to avoid this again..
    May 2011
    Norfolk, UK.
    171
    Jul 2009
    Newport Beach
    2,418
    How are your motor mounts? The pan should be higher than the subframe and out of the way with good condition mounts.
    May 2011
    Norfolk, UK.
    171
    Quote Originally Posted by Byron View Post
    They look fine. The sump is just visable lookin under from the front of the car, probs a few mm's. Enough to be a pain though. I don't want to change it again!!
    Jul 2009
    Newport Beach
    2,418
    They're sagged then, and softer due to age. Get new ones and throw a washer or 2 on top for peace of mind and you should never have a problem again
    May 2011
    Norfolk, UK.
    171
    Righto. I still want to raise it as much as I can though, get it as high as possible. Uk roads are shit..
    Jan 2010
    Perth, Scotland, London
    7,351
    SS Autoworks make engine raiser kits. They're UK based, might be worth looking into
    May 2011
    Norfolk, UK.
    171
    Quote Originally Posted by Minuki View Post
    I've seen pics of them. I've made the same sort of thing..
    I can't find out how much it can be raised without compromising the driveline (prop/diff etc) and don't want it to vibrate like a dildo!
    I've made mine at 25mm but don't know if it's too much, some say 20, some say 25mm. I might just chop 5mm off each and go from there.
  9. #9
    im good friends with the guys at ss, can vouch for their stuff.
    for my friends 36 we ditched the stock mounts and used hockey pucks. like 4 iirc. engine was pretty much as high as it could go before it started fouling on stuff. obviously the pucks were alot harding and it was like running poly mounts so vibration at idle was increased, but it allowed him to run crazy low static. heres a video
  10. #10
    Just get an x-brace. Acts like a skidplate
  11. #11
    Jan 2010
    7,351
    Quote Originally Posted by groundpilots View Post
    Acts like a skidplate until it eventually pushes into the sump and obliterates it. I ran one for 3 days and it sucked.
  12. #12
  13. #13
    May 2011
    Norfolk, UK.
    171
    I made some in the end. 25mm on original mounts. As high as it can go now. Very slight vibration at idle but none on the move.
  14. #14
    I currently run a x brace on my 36 and it catches crowns in the road that ordinarily it wouldn't have caught due to that brace now being the lowest point on the car (about 5cm ground clearance), it makes a disgusting noise when it hits tarmac too!
    Be interesting to see what you come up with on this as i'm contemplating removing my x brace..
  15. #15
    bump for updates?
    Anyone else with a raised e36 engine?
    I'm considering the condor engine risers (20mm)
  16. #16
    Quote Originally Posted by Jvstin View Post
    bump for updates?
    I'm considering these as well since they're only 50 bucks. @donlin259 on IG runs them and he's dumped to the ground so I'd say they're pretty good.
  17. #17
    Jan 2010
    7,351
    I've raised mine a good few mm, sits above the subframe now.
    Most of the problem is down to worn engine mounts, swap them out for some new ones and it should sit above the subframe, if you manage to hit it then, you're doing pretty well.
  18. #18
    Apr 2018
    South Carolina
    17
    busted oil pan sucks!
  19. #19
    Aug 2015
    Essex/London - UK
    525
    I make these engine raisers to stop your sumps getting smashed. doesn't cause any issues to the drivetrain or running gear.
    there is a for sale thread on here, failing that Instagram me @benwalsh91
    Instagram - Benwalsh91
