Page 1 of 3 123 LastLast
Results 1 to 25 of 58
Thread: Project 911 Something, Building The Dream.
    Aug 2014
    Costa Mesa, CA
    33
    Default Project 911 Something, Building The Dream.
    My name is Evan, and this is my 1975 911 long term build......... emphasis on long term.
    I have a background in racing and this was supposed to be just a cheap fun car after growing tired of having a trailer only race car.
    It all started so innocently.
    And then I started to Autocross it.
    And that lead to going back out to the track.
    Which inevitably led to the realization that 38 year old 3pt. belts and stock seats wasn't confidence inspiring when pushing the limits.
    https://www.youtube.com/watch?v=jNTR689b0t8
    And so the build began.
    Aug 2014
    Costa Mesa, CA
    33
    Lots of floor tar and glue to be removed.
    Making progress.
    The factory sound deadening glue had caused rust to form under the paint where it was applied so the only solution was to grind it all back.
    Which led to doing the engine compartment as well because while making a mess......
    With all the floor tar, undercoating and seam sealer gone, finally some primer.
    Oct 2010
    riverside, cali
    402
    this thing is beautiful, I can't wait to see what you do with it
    Aug 2014
    Costa Mesa, CA
    33
    Then a test fit of the new composite doors and it was off to the fabricators.
    LucasFab in Huntington Beach handled the cage fabrication based off of my design and I couldn't be more pleased with the results, he is one talented guy. Sure it's built like a tank, but I always liked the look of a stout, well designed cage. Having gotten used to the chassis rigidity of modern race cars, I wanted to stiffen up this early tub as much as possible. Primary cage construction is 1.75"x.095" 4130, with additional braces and gusset tubes out of 1.25"x.095".
    Tie in for coil-over rear suspension.
    Lots of tie-ins in the front trunk.
    Stitch welded into the car where ever possible.
    Lovely nodes.
    And the signature LucasFab Union Jack door bar arrangement.
    Pure weld porn.
    A simple flat X on the passenger side, gusseted correctly for proper load distribution in the event of a side impact.
    Aug 2014
    Costa Mesa, CA
    33
    And the fabrication continues, a test fit of the seat onto the modified floor and Cup car sliders before adding any more gussets.
    Crash bar in front of the gas tank.
    Further gusseting for those times when the car takes flight.
    Yep, the gas tank still fits!
    Jun 2014
    Alkmaar, The Netherlands
    147
    Wow this is some nice progress!!
    Jul 2014
    Lone Star State
    1,423
    An e30 and this right here are the only 2 cars i'd ever fully rebuild for track use. This is awsome, amazing fab work on that cage as well. Can't wait to see progress. Sub'd
    this is awsome, amazing fab work on that cage as well. Can't wait to see progress.
  9. #9
    Jan 2012
    Los Angeles
    6,045
    That cage is pure porn.
    Can't wait to see where this goes.
    IG: @sebastienaudeon
    1974 Porsche 911S
    Quote Originally Posted by TRaNz View Post
    *pats Sebs head*
    there there.
  10. #10
    Mar 2011
    Houston
    294
    That's awesome! Keep up the good work
    @clay_mation
  11. #11
    Oct 2009
    Long Island
    2,694
    oh boy... i can't wait till i can start a project similar to this
    making me hugely jealous
    1982 euro porsche 930 turbo
  12. #12
    Any plans to freshen up the engine? That cage is beast and the car is indeed pornworthy
  13. #13
    Aug 2014
    Costa Mesa, CA
    33
    Thanks for the kind words guys, its been a long build and still has a long ways to go.
    Tecknix, The motor I have for the car is a small port 3.0L with roughly 40k miles on it. The plan is to pull the heads and port them to large port specs (open up the intake port from 35mm to 39mm), ditch the CIS, and adapt on a VarioRam intake from a late model 993 (multi-lenght intake tract intake that should boost midrange torque by 15-20ft/lb). This requires custom injector holders and fuel rails be made which i'm in line for at the machine shop. To run the intake I will likely end up with a M84 Motec which will allow the use of coil on plug ignition and clean up the engine bay greatly. Coupled with some trick stepped headers, it should be a good reliable 220-230whp motor. As much as I would love a hot rod motor, it will have to wait. Just getting the car back on the road with the mods I want without cutting too many corners is Job #1.
    Coupled to the motor will be the original '75 915 gear box that has been refreshed with all new syncros and dog teeth, and upgraded for race use through a Guard 80/80 diff, and WEVO internal spray bar and trash filter set up for an external cooler. Upgrading to a G50 box and/or short gears will have to wait till a later date.
    You can just see the tip of the spray bar where it squirts on the pinion with what is left of the volume that didn't come out over the 5 gears.
  14. #14
    Nov 2010
    Belgium
    154
    Oh lord!
    @nico_2polished
  15. #15
    Aug 2009
    NorCal
    1,398
    wow...damn impressive
  16. #16
    Jul 2014
    Reading, UK
    24
    Always loved the older 911's, look forward to seeing where this goes, sub'd!
    Oh and that cage is so beautiful <3
    Instagram: @KingCavey
  17. #17
  18. #18
    Aug 2014
    Costa Mesa, CA
    33
    The metal work continues.
    Block off plates for the HVAC vent holes.
    All this cage is going to require some bigger fenders. Below 300hp or so, I am not convinced the added drag of going to turbo fenders pays off from a performance stand point so Carrera fenders are going on.
    Measure twice, cut once.
    And now time to get rid of the sunroof. Tried a couple different plugs to close the hole and none of them fit all that well so the only solution was a roof swap with a non-sunroof skin.
    A little paint while things are easy to get to.
    I wasn't quite brave enough to try it so body man, John Esposito, stepped in and unrolled the rain gutter to swap just the skin and rolled it all back up.
    And now, finally, test fitting the new shoes! 8.5" and 10" by 18" Fikse's,
  19. #19
    Dec 2013
    Seattle
    2,269
    Holy shit Fikse wheels?
    Damn im jealous now
  20. #20
    Love it,keep the updates coming!
  21. #21
    Aug 2014
    Costa Mesa, CA
    33
    Quote Originally Posted by SnazzyQ View Post
    Damn im jealous now
    Let's just say, one of my jobs at work has a way of imparting an appreciation for premium wheels.
  22. #22
    Jan 2012
    Lexington, KY
    1,014
    This is freakin dope dude. Subbed
  23. #23
    Sep 2013
    Orange County
    8
    subbed! awesome build so far. local to you so I hope to one day spot this on the road!
  24. #24
    awesome, i'm so jealous
  25. #25
    Aug 2014
    Costa Mesa, CA
    33
    As project creep continues, this thing showed up. G50 Torque tube out of a '87-'89 911 that will allow me to move the drive train forward slightly as well as fit a G50 transmission when/if I ever get a big motor.
    Cut a big hole in the back seats.
    And voila (if only it were this easy), lots more work to get this thing swapped in.
    After a couple years of bouncing between shops getting the heavy fab work knocked out after hours, I built a shed to house this thing in my parents back yard and dragged the whole mess home.
    It all fits but got to get rid of what is left of my Kinesis hoarding after deciding I wasn't going wide body.
    It did look pretty cool though with 10s and 13s.
