Stance Solutions Static+ Kit with Compressor etc
  • Stance Solutions Static+ Kit with Compressor etc
    I have built this kit over time with plans to fit it to the right car. I have decided to go in a different direction.
    So the kit.
    Stance Solutions Static+ Cups For 22mm Shafts (new)
    Viair 380c Compressor (new)
    Airlift Paddle Valves x2 (new)
    Various connections (new)
    Glow Shift Single Needle Gauge (new)
    Gauge For Tank With Fitting (new)
    Air line (new)
    Cut off switch, 90psi on 120psi off (new)
    2 Gallon 3 port Tank (could be new but needs a paint)
    Everything is there to run the kit except for the wiring. Pretty sure you can run the compressor from a amp wiring kit.
    I have 2 paddle valves to run the cups independent to each other to stop them feeding across in the corners.
    I have included one Glow Shift gauge to moniter the tank pressure from up front and also a basic one to moniter from the rear.
    I am located in Bolton Nr Manchester 07805406378
    Looking for £650ono Collected due to size. Could maybe meet somewhere.
