Raceland? To be or not to be.
  • #31
    I just got mine today
    But i have some qustions, i'm going to slam my E36, but i heard that the fronts bounce and the rears doesnt go that low
    Should I take off the helpersprings?
    Cut the bumpstops i half?
    Remove something in the rear adjuster?
    • #32
      The fronts suck. I drove with the rears only installed and loved it, when I put the fronts on and drove, I ***** life. So bouncy.
      For the rear, I took the adjuster out so its just the spring. Its low enough for me.
      I cut the bumpstops in half for the front, apparently it helps with the bounce. I have yet to drive with the bumpstops cut yet.
      -Dan
      • #33
        the guys on clubroadster are rocking these things
        guys have placed in teh top 3 in autox against must more expensive suspension at equal experience supposedly. i cant say go for it, but the data is somewaht tehre that they dont suck completely
        Disclaimer:
        I am rude, opinionated, and sometimes come off as a dick. I am just speaking my mind. If it offends you, PM me. Don't go whine to someone else. I am civil, talk to me, just dont be stupid.
        and USE THE SEARCH BUTTON
        • #34
          A few guys on GolfmkV are using these for auto-X duty and they're holding up great.
          • #35
            Should I remove the helperspring?!
            • #36
              if you wanna go lower yea... .. why not?
              ig: @jonnie86
              • #37
                I havent but them on the car yet, but would the car ride better if remove the helperspring is more the question
                • #38
                  No, it'll ride worse. But that's the price you pay for moar low
                  • #39
                    I'm literally sitting on the bumpstops on mine and it's not that bad (only over certain surfaces/series of dips) .., but I'm scared if I cut them, I'm gonna destroy the fenders the first time I go over a bump while turning because there is literally a couple mm between my tire and fender.
                    • #40
                      NO. if you have them for the e36, i can vouch you WONT need to do that. dont even put them in zeroed(fronts) if you do you will be sittign frame on ground.
                      • #41
                        The general style discussion forum, as well as a place to post your car, or any car for that matter.
                        (im not home so i cant post pics) but thats with around 1" of thread left on the front. the front looks higher than it is. my subframe is almost on the ground.
                        • #42
                          Yes, it's for my E36... I mounted them yesterday, they are turned all the way down and I just tuck the tire a little bittle How much will they drop once the springs settles?
                          The rear are very low tho
                          • #43
                            Say what now? O_o It's the exact opposite for me.
                            Look at my sig: the front can go down another inch and the rear is maxed out (and not really low).
                            • #44
                              ^ you have helper springs in the front still?
                              www.effineuro.com
                              • #45
                                Racelands settle quite a bit...almost .5" There are some "freak" sets out there that settle like 1.5"-2"...I think dfresh has one of them. They just inexplicably go lower than other Racelands...but most are like yours. Pull the front helpers, and the rear adjusters too if you can.
