Page 1 of 8 123 ... LastLast
Results 1 to 25 of 186
Thread: My 1997 M3
    Feb 2013
    Ashburn, VA
    312
    Default My 1997 M3
    Well, first real build thread I've done so don't be too harsh on me.. Picked up a '97 Techno Violet M3 after selling my 1995 Hellrot M3. Seems like everyone and their mother has an E36 now, anyways onto the build...
    Bought it with 116k on the odometer and some simple bolt ons (Dinan CAI and UUC twin canister exhaust). The M3 now has 118k since it's been sitting awhile getting the whole rear suspension/subframe replaced. All polyurethane bushings in the rear now. While that was happening I ordered a set of BroadwayStatic coilovers. Thanks to Peter for all of his help! Have a set of wheels on there way from Germany... Anyway enough talking and onto the terrible iPhone pictures
    Here it is the day I got it
    Here it is four months later...
    Terrible roller my friend took, I think it's kind of cool though...
    That's all I have for now, but will keep updating as I go. Thanks for looking!
    Instagram: @mattragsdale
    '97 M3 build
    loving the purple, in for more!
    '82 Volvo 242 build
    '73 Datsun 240z build
    Feb 2013
    Ashburn, VA
    312
    Quote Originally Posted by aprophet13 View Post
    Thanks man!
    '97 M3 build
    Feb 2013
    Ashburn, VA
    312
    So my wheels are being shipped from Germany...
    Terrible pictures, but they are the sellers photos so nothing I can do about it. Huge thanks to @angelmisskitty! She sourced these for me and they should be here by the end of April. The guy that owned these previously has had them for the last 10 years... Specs are 17x7.5 5x120 et34. Doing a rebuild on them so stay tuned.
    '97 M3 build
    Feb 2013
    Ashburn, VA
    312
    Default My 1997 M3
    So this happened the other day....
    Tried my best to pull it back in
    Is this fixable? Or will I need a new fender? Willing to take it somewhere, but where should I take it if that's needed...
    '97 M3 build
    Jul 2013
    FLA
    65
    I did that to my fender...... Repeatedly -.- fck.
    You may be able to smooth it some with body tools but I'd stay away from any filler and just buy another if you want oem cleanness again. Otherwise your off to a damn good start. :raisesfist:
    theory87.com
    ig: _coreyw
    Feb 2013
    Ashburn, VA
    312
    Quote Originally Posted by Korito1887 View Post
    Yeah... I was told I could use a C clamp or something of that nature to straighten it as much as possible so I might as well try that before purchasing a new fender.
    Was told removing fenders is hard by a co-worker, but it seems pretty easy. I'm going into it having no idea how to replace a fender...
    '97 M3 build
    Jul 2013
    FLA
    65
    Hard? What could be hard about it? I would think it's no harder than changing oil.
    theory87.com
    ig: _coreyw
  9. #9
    Jul 2013
    Pennsburg, PA
    168
    Taking the fender off or on isn't typically the hard part - it's getting the fender lined up properly that is. To get all of the gaps right can be challenging, and may require a shim or two.
  10. #10
    Feb 2013
    Ashburn, VA
    312
    Quote Originally Posted by speakerboy View Post
    What he said...
    '97 M3 build
  11. #11
    Jan 2014
    Near Munich, Germany
    591
    I would replace the whole fender, it may be a bit of work, but it's worth it. Nice colour by the way, I'm in for more updates.
  12. #12
    Feb 2013
    Ashburn, VA
    312
    If anyone in the Northern Virginia area has any experience with body work, I would greatly appreciate it if you could help me out. I'd be willing to travel a little bit for some help as well.
    '97 M3 build
  13. #13
    Feb 2013
    Ashburn, VA
    312
    UPDATE
    Yes I know, the car could use a lot more low in the front, but it just got an alignment and I don't want to screw it up. Pictures are by a buddy of mine, Chris.
    I'm in need of some rear camber arms. Any suggestions? Heard SPC has a lot of adjustment.
    '97 M3 build
  14. #14
    Apr 2012
    Brambleton, VA
    332
    Looks good! I'm in Northern Virginia as well. Funny because I drive a '95 hellrot m3. I bought it down in Raleigh, NC though.
  15. #15
    Feb 2012
    West Bend, Wisconsin
    2,116
    I see you have met Kitty too=) Your build is definitely headed in the right direction=D
    95 318ti & 96 328is
    Compact Build Thread
  16. #16
    Nov 2011
    Weston, FL
    1,224
    Very nice you can't go wrong with Techno Violet.
  17. #17
    Feb 2013
    Ashburn, VA
    312
    Quote Originally Posted by pDubs View Post
    Hope to see you around sometime, and thank you
    Quote Originally Posted by Earl View Post
    Yes, I have! Thank you! I have a couple questions for you.. check your pm!
    Quote Originally Posted by Chasen88 View Post
    Thanks!
    '97 M3 build
  18. #18
    Feb 2013
    Ashburn, VA
    312
    Default My 1997 M3
    Haven't updated here in a while. About two weeks ago I received my Bear Motorsports short shifter. Installed that and it took way longer than it should have.
    Also, just received two out of my four wheels in the mail yesterday. USPS said the package was "too heavy" to deliver to my front door... Anyway had to wait another day to get them. Here they are!
    Will get better pictures once I have time to. Super stoked on getting these rebuilt. Ordered lips about 2 weeks ago from Paul at Ewheelworks. Also just received a few parts in the mail. Rear adjustable control arms and poly trans mounts. Will post once installed.
    Any opinions on wheel color?
    '97 M3 build
  19. #19
    I'm in North VA too!
    I'd suggest paint matching the amber in your taillights for a wheel face color...or just white all the things.
  20. #20
    Aug 2011
    Bethlehem, PA
    594
    Can't wait to see the wheels done! Paul is an awesome guy to deal with, just got new lips and barrels from him for my Mitos
    3/96 Build Date, Montreal Blue, 304,310 miles and counting...
  21. #21
    Feb 2013
    Ashburn, VA
    312
    Default My 1997 M3
    Quote Originally Posted by lublub View Post
    Yes I am doing all euro lights so I think I'm going to go with silver faces!
    Quote Originally Posted by e39hamann View Post
    Yes, he's awesome and I'm also exciting to get these wheels fitted on the car!
    UPDATE
    Rear lips came in. They are 3 inches and I also got a couple decent pictures. Anyway here they are
    Not the best, but the car will look 100 times better once I get the wheels on.
    Any suggestions on tires? Going to need a decent stretch as you can see. I was thinking 205/40 on a 9 up front and 215/35 on a 9.5 rear. Found the rear tires by Hankook but not the 205/40.. Any help would be appreciated!
    '97 M3 build
  22. #22
    Feb 2012
    2,116
    I have 205/40's on my 9.5's and 215/40's on my 10's. The tires are Hankook HR2
    95 318ti & 96 328is
  23. #23
    Feb 2013
    Ashburn, VA
    312
    Yeah, I'd like to run as small of a tire as possible in the rear so I was thinking of the 35 series. Don't want to pull my fenders too much. I'd like to run a 35 series up front, but no one makes a 205/35/17
    '97 M3 build
  24. #24
    Nov 2012
    Egypt
    876
    Great color. I wanna see the Futuras on ASAP
  25. #25
    Feb 2013
    Ashburn, VA
    312
    Quote Originally Posted by Queef|Chief View Post
    I want them on as well! Need to repaint the faces and centers then we will be good to go. I'm sad I'm missing SOWO this year.
    '97 M3 build
