Page 7 of 7 FirstFirst ... 567
Results 151 to 162 of 162
Thread: The Fabrication/Welding Thread
  1. #151
    Been lurking on this thread for a while now thought I'd introduce myself in here since its where I'll be most lol.
    Names Rudy and I dig fab work
    Some of my work:
    One-off bumpers, winch tub, roof rack, tire gate and ladder on this xterra
    GTS/SP996 cages
    International Scout bolt in cage
    and some sick machine work i had done on my own project!
  2. #152
    Jul 2014
    Montreal, Canada
    216
    First real welds I've done (other than a few practice lines). I'm currently running flux wire using a Mastercraft Mig and Flux Welder. Any comments? I did stop in between the 2 left welds.
  3. #153
    Mar 2012
    Kensington, CA
    179
    Not too shabby bud, although looks a little cold. You can prolly run a little hotter and faster, especially on that 1/4" steel. See how high the weld has built up? Maybe try 5-10 more amps and moving at a faster travel speed. If they're still building up a lot you can turn the wire feed a little slower. Most importantly tho, KEEP WELDING! Don't just go out and do 10 mins of welding and call it a day, try to repeat your process of the better welds once you make them, it'll help you retain better habits/form
    conversion syndicate*
    ig: makercruuz
  4. #154
    Oct 2013
    Louisville, KY
    33
    I picked up some eBay BMW stainless headers from a friend to put on my Mercedes. I'm sure the stainless is inferior since they are already rusting. This is more or less a trial run to see how they fit and work. Can I cut the cast flange off of my manifolds to weld to the stainless? My other option is buy a flange from Australia at $118 shipped. It's mild steel.
  5. #155
    I made a tow hook and oil checking step for my 79 K10. the step is mounted to the push bar and the hook is bolted to the frame
    the hook was cut out of a piece of scrap i had. it is about 3/4" thick and my Hypertherm 30xp isnt even rated to cut that much so im lucky i got it as smooth as i did. its very hard to trim little bits off like that so its not perfectly shaped.
    i made the step out of a scrap bracket and what im guessing is a section of track for a machine of some sort. we have the same track on the floor for the machines to open up on at my work.
  6. #156
    Nov 2012
    London, ON
    135
    That step is actually really cool looking! Nice work!
  7. #157
    thanks dude
  8. #158
    Nov 2011
    In the woods
    890
    Quote Originally Posted by Greg View Post
    You can most definitely do so but be careful; ebay stainless tends to be very thin and welds pretty poorly with a MIG (as does all stainless). Blow-through is easy if you're not paying attention.
    I would also suggest grabbing an exhaust manifold from the junkyard so you aren't cutting up your only good one for a flange.
    Instagram: surpriseitsmicah
    Builds:
  9. #159
    No idea if it's still relevant or what benz you have. But if its a 124ish era, and a v24 motor like 300-24/320/280 or even maybe a 300 v12, you can search local junkyards or ebay for a set of later stainless manifolds. as they have a fat flange that can be used for that.
    Edit: that custom step is da bomb
  10. #160
    Nov 2014
    Laguna Beach,CA Glendale, AZ Soon to be Boston
    1,018
    Greg I really hope you end up fitting BMW headers on the m103, if you do I'll pay you to make a second set!
  11. #161
    Made a poor mans high tech turbo brace for the spoolyboy
    Attached Images Attached Images
  12. #162
    First time welding a rollcage:
    This is on my S13 240sx
Tags for this Thread
