Window Brilliance Tip
  • Window Brilliance Tip
    Im sure some people already know about this, but if you want the glass in your car to be stupid clean and clear- use a clay bar and pre wax as if you were claying the rest of your car. after i do it i can barely tell if my windows are up or down. just a friends fyi
    Ant suggestions for cleaning the inside? I ALWAYS end up with at least small streaks.
    theory87.com
    ig: _coreyw
      I do the claybar on the inside too man. never fails.
        I can always tell if my windows are up because my tint makes it obvious.
        Y'all know me, still the same OG.
          What brand of clay bar?
          Sugar Mama Build - http://www.stanceworks.com/forums/sh...ad.php?t=73298
            Brand doesn't matter. I use one from Griots Garage.
              you guys should try a really fine wirewool #000 or #0000. combine it with some good glasscleaner and gently work it over the glass. works in the same way as a claybar but much much cheaper!
                Exactly. I had hard water deposits on my windows for years, and I couldn't figure out how to get all of it off. But one day, my friend recommended going with like #0000 and it finally did it for me
                Originally posted by cobrawannabe
                More lotion.
                My build thread
                Instagram: Franswishaaa
                  Hey guys,
                  Whats the best way to remove window tint in this cold weather weve been having?
