Hi kids, this might be a stupid question, but electrics aren't my thing. I just installed an Accuair system (e level) and I'm testing out the manual controls. I wired everything in (using the kit's relay).
Q: When I hook up the battery, the relay clicks once, but when I turn the key to turn on the compressor nothing happens. I tried the compressor indvidually and it starts. Why isn't the compressor starting?
Also the car is an old Mercedes diesel so I wasn't quite sure were I can hook up the 12V+ for the signal, so I found a terminal on the fuse box that gives a voltage with the key on.
Cheers
Cheers
