W201 v.2.0
  • Looking very cool bro.
    BMW M5 V8 1993
    Slowtoys CC
    • Originally posted by herrakani View Post
      Thanks heres more...
      Final version of brakelines.. this is 2nd version overall, i like how they are now, and best of all both front lines are 1 piece lines.
      Now: MB W211 320cdi
      Ex:MB 190E M50, BMW E39 530d
      • You don't run a linelock?
        BMW M5 V8 1993
        Slowtoys CC
          Maybe on rear.. would be ok to run linelock on rear with solenoid, i could lock it either in brake or brakeless mode. for burnouts and for keeping the car still.. will see in future.. and if i do, i will hide it somewhere in rear where no one can see it and never talk about it again
          Now: MB W211 320cdi
          • Sooo clean work Nice!
            Life is too short to stay stock. Astra from Lithuania build thread
            • Rear brakeline..
              Mockup.
              DONE!
              Other than that it was crap of a day..
              came to garage it was like this:
              but driveable on big roads..
              when i was leaving ...
              So ~10 to 15cm of snow.. so i had to take be bmw on the back to get home.. and what was nice it has 3.0 turbo diesel engine and 4wd and winter tyres.. but the issue it wont blow any hot / warm air at all!!! so heater control valve stuck propably. or something like that.. was a cold ride home.. altho i got home safely.
              Now: MB W211 320cdi
              • Seems to depend much on the spot you are, literally no snow on Lauttasaari when I left work but 10cm at home. Disgusting. I still got some work left on my dd before I can start grinding the M5.
                BMW M5 V8 1993
                Slowtoys CC
                • difficult choice
                  hot and sketchy
                  or cold and safe
                  Floccinaucinihilipilification
                    Are you going to run it this year?
                    difficult choice
                    hot and sketchy
                    or cold and safe
                    Actually no, it was beyond sketchy and i found out about 5km out of garage that it wont have any heat inside. but i foundout today the issue its the "heater control valve" or what controls it. once i unplug that... heat.. so works for now.
                    Now: MB W211 320cdi
                    • Originally posted by Exami View Post
                      Hope so. Depends on the monies..
                      BMW M5 V8 1993
                      Slowtoys CC
                      • Moving slowly forward...
                        Can interface.
                        Display, will fit quite ok on the stock cluster
                        And rear brakelines:
                        Next up brake hoses and im pretty much done with the brakes. in couple days i will get fuel lines 10mm RST Pipe, some new bits for the rear diff, so going to redo that soon.
                        Now: MB W211 320cdi
                        • Things going forwards and backwards all the same time..
                          First off when i popped the oilpan out, this fella came out..
                          ... about 2seconds later ...
                          No worries its only oilpump...
                          New fuel lines in da garage:
                          2x 4m of 10mmx1mm Stainless pipe.
                          Front brake caliper dont fit...
                          New rear subframe... soon time to modify
                          Also paintshop has been asking for the car so maybe soon that as well
                          Now: MB W211 320cdi
                          • Its not done yet!
                            Been working with the rear subframe.. (jig almost done)
                            Fuel returnline 10x1mm pipe
                            Now: MB W211 320cdi
                            • Bits has happened since last update: just let the photos show..
                              Brakelines:
                              Subframe stuffs
                              Fuel line stuffs:
                              Now: MB W211 320cdi
                              • Great work so far!
