Results 1 to 2 of 2
Thread: e36 engine swap/thoughts...
    Sep 2013
    South Bay, CA
    3
    Thumbs up e36 engine swap/thoughts...
    I have 1994 325is coupe and just recently bent valves on my engine for the second time -_- and instead of repairing it, im thinking of just swapping it for an s52b32 engine (found one for 1500 comolete long block). Now I know my car is obd1 but that s52b32 is obd2 I know I can easily convert it to obd1 since all my obd1 parts can fit on the s52 engine but my main question is would I still be able to pass smog if I pretty much use the bare block and head from the s52 and bolt on my obd1 parts (intake manifold,sensors,vacuum lines,emissions stuff, etc.)
    Thanks in advance for any input.
    Aug 2009
    Space
    3,175
    should not be any problem at all.
    -Instagram@jdjurhuus
    Stretchsaurus and Pokemon.
