e36 skid plate
  • #16
    Lol your e36 sucks, every other e36 pan is so far from danger it's not even funny.
    • #17
      Lol 318s.
      Drop a M52 in there, never worry again.
      - Kielan (Key-lin)
      • #18
        Ouch, never looked under a 318 before
        • #19
          I didn't think it was the pan was that low either. But I guess I was wrong.
          - Kielan (Key-lin)
          • #20
            Washers under the mounts. 318 issue solved. Also I'm super jealous of E36 owners clearance.
            • #21
              lol well put and very true. who would have thought the smaller, slower, slant 4 oil pan would be more exposed then a straight 6?!
              Well looks like ill be raising this motor as well
              HoodRatStatus
              Instagram @looneylow
              • #22
                street sign.
                nhoJyauQ/John Quay
                E36 Vert Build
                Instagram @nhojyauq
                • #23
                  Post up some updates
                  • #24
                    read this thread almost a year ago and thought i was fine until recently i cracked my pan on my e36.
                    need to get an x brace.
                    CUSCO USA // BRIDE JAPAN
                    • #25
                      mine has saved me several times...
                      nhoJyauQ/John Quay
                      E36 Vert Build
                      Instagram @nhojyauq
                      • #26
                        people can't afford a
                        • #27
                          I've been I the process over a year testing my skid plate. fixing the errors and finding
                          out where the flaws could be.
                          duplicated my skid plate yesterday and selling this one now,
                          comes with the nurserts that need to be installed in the subframe with the Allen bolts that fit flush in the skidplate do the heads don't get worn down, the holes are countersunk, I also provide a 3/8 thick 3x16 aluminum spacer that goes In between the skidplate and subframe. the skid plate sits up higher then an xbrace. xbraces end up bending into your oil pan and eventually will crack your pan. skidplate has about 1/4 inch or more clearance from the oil pan. the rear of it bolts directly to your frame rails. messag me of interested.
                          oh and I'm pretty low. trust me when I say my skid plate saves.
                          • #28
                            i suggest raising your motor AND getting a skid plate
                            -The Beauty in the Tragedy-
                            Got Drop??
                            • #29
                              There is actually a factory x brace that came on e36 m3 verts that would protect the oil pan pretty well and if you wanted to get craft you could always weld a plate on it. Part number is 51718410212. Hope this helps someone!
                              • #30
                                what street signs are made for.
                                nhoJyauQ/John Quay
                                E36 Vert Build
                                Instagram @nhojyauq
