Wheel fitment, could use advice from e30 owners
Originally posted by 610EURO View Postyes. they are stupid. stale has had some decent wheels, and some wheels that looked like really expensive garbage. the 18's looked terrible.-Instagram@jdjurhuus
Stretchsaurus and Pokemon.
16x9's are going to poke up front in an e30 unless you run some camber, no matter what. et12 is the highest you can go before you hit the strut tube.
As for the rear, on a low car the camber makes the rear wheels sit about 12-15mm farther in than the front. So if you were running the 16x9 et12's up front you would want about et0 in the back to match.
If you go with staggered sizes:
1/2" stagger- 7mm less offset than the front
1" stagger- same offsets as the front
etc.
Remember that because of the strut tube angle,15's wont be able to run as high of offsets as 16's, and 17's will be able to run more.
Originally posted by Madface View Postthis is my car, 9 et 12 front and 10 et 12 rear. the fronts barely clear the struts, maybe a credit card thickness between them.
edit: forget it..I'm too tired :p thinking like an ass.Last edited by famguy; 03-18-2010, 05:10 PM.- '89 E30 M-Tech 2
- '10 TT RS
- '13 A3 SB
Originally posted by Zic View Post18''s are stupid eh?
well, not in my opinion.
