The BBS RC 090/BMW Style 5 wheels thread
  • Originally posted by MIGS View Post
    my questions to you guys who retain the style 5 centercap... where the hell do u get the BBS center cap/emblem from??
    I've searched everywhere and can't ever never find the correct size
    70mm style b and you have to cut off the tabs and glue it in place because there are none made specifically for these wheels
    You can get them at purems.com or blackforestindustries.com
    • I've made a BBS RC or Style 5 configurator for E30 M3, cause I finally got a second set of BBS as the one I'm using now and I'm not sure of how to paint them, i have made it usign photoshop so you will need photoshop to use it, hope that you like it:
      • Joining BBS RC fanclub sorry for low quality, later will be better! Setup: 205/40 front and rear, BBS RC 090 8j ET20, FK AK coilovers, rear maxed out, front still can go way lower, too bad i cant do it because roads here are just terrible, NO spacers, very happy with the setup
        • Comment
          • Comment
            • Originally posted by hakhawk View Post
              whered you get the gold bolts
              EURO.TECHNIKS | BAGGED E46
              Instagram: @_victorg
              • had them cad plated locally, theyre not real gold
                  ah man ive been trying to find gold bolts forever lol
                  every place is out of stock
                  I think im going to order regular ones and plate them gold
                  • Just found out the place who nickel plated my bolts can do gold as well.
                    • Originally posted by einstein57 View Post
                      Link please!!!
                      • I just got my style 5's and I bolted them up quickly for a test fit and they don't clear my brakes!
                        I have a 2001 330ci and the bolts on the inside of the rim seem to be rubbing against the caliper when I spin the wheel.
                        My plan is to grind/sand down the caliper slightly and then stick a 5mm spacer in addition to the hub centric ring.
                        Anyone else experience this issue?
                        • Originally posted by dlandon View Post
                          Had the same issue and had to grind the caliper after installing new pads. all fine now
                          • Yah I have a feeling that when I refinish them, the bolts might even stick out more.
                            Hopefully grinding + 5mm will clear it.
                            • Originally posted by dieseldubber View Post
                              What do you guys think?
                              OPTION 1
                              72.5 to 74.1 hub centric ring
                              Then a 5mm @ 74.1 spacer on top?
                              or
                              OPTION 2
                              5mm @ 72.5 spacer
                              Then 72.5 to 74.1 hub centric ring on top?
                                OPTION 1
                                or
                                OPTION 2
                                5mm @ 72.5 spacer
                                option 2 so you can reuse the spacer on a next set of wheels that may not be 74.1.
