FC RX7 5.0 race car thread
  • Very nice work so far. I'll be checking in for updates for sure!
    • Originally posted by Suburuuh View Post
      The start (and running) of an engine in a build is like putting fuel on a fire!
      This gives even more motivation to continue and finish it.
      Haha yup!
      Loved your bug eye when it was on works!
      87 RX7 5.0 (driftcar)
      • Originally posted by pDubs View Post
        Thanx! I'll keep posting them
        • Originally posted by Teeson1111 View Post
          Haha yup!
          Thanks! Kind of missing the Bug a bit after almost a year now.
          But this only fuels my veins with more exitement to do something new.
          Perhaps soon already, working on that as we speak.
          • Car is looking great! Reusing the factory harness has been a struggle for me as well, and having nearly non-existent soldering skills hasn't helped lol. I'm falling so far behind you, its hard to not run into the garage every time I see an update to this thread!
            On your 3 fuse panels you have...are those just the $10 apiece ones you can get on Summit and Jegs? I was thinking about using those as well, was just curious if they're decent enough quality. The glovebox setup will be pretty cool, I was going to shove it in the storage bins but I'm curious to see how yours turns out.
            • epic job here sir
              • Originally posted by Zach Thomas View Post
                Ya the fuse holders are Hella, very good quality.
                I would throw everything back there if I had an interior lol.. Glovebox ends up being a shorter run as well..
                Originally posted by aeok18109 View Post
                epic job here sir
                Thank you!
                • You should ditch the whole plastidip idea - You did really well painting the inside and roll cage (which one was painted first??)
                  So just continue with that and paint the entire car!
                  • Originally posted by TeckniX View Post
                    lol thanx! but no... It worked ok (looks better in pictures probably) I think because the stuff I painted was huge and flat. The hood and much of the body would be really hard to get clean with rattle cans.
                    Plastidip offers the ability to change colour often too, and easy to repair
                    I painted the cage first, then masked it and painted the interior.
                    minor update:
                    been rocking out to this. Found The Parlor Mob some time ago from a random snowboarding movie (Iseneven - Let's Go Get Lost (great movie)) and quite enjoyed the rest of the album. Haven't heard much of their new stuff but it seems a step away from the kinda small time rock band sound they have. I wish I could sing along a little better too, but it doesn't stop me from trying haha
                    IMG_6242
                    did some heavy gauge wiring
                    IMG_6241
                    quite time consuming actually heating up the terminal, filling it with solder, dipping the wire in it, heat shrink, route it and check length. Repeat. Then I ran out of 1/0 so I need like 3 ft more or so.
                    IMG_6238
                    tried (yes tried) to watch Formula Drift in Atlanta while working, but between my poor internet and the drift stream being cranky I didn't get to see very much. Oh well, Cory Hosford still liked my IG of it haha. Made my day.
                    IMG_6240
                    made a mock panel out of MDF I had laying around, this way I can change things if need be. I have it so I can swing it in and out of position so I can check wire lengths but still actually work on it.
                    IMG_6235
                    we attempted to weld that diff mount I modified... that didn't work
                    IMG_6233
                    the rubber was catching on fire and the gasses created were blowing holes through the weld pool. So after about halfway we just called it. I'll be buying a Parts Shop Max one later, this is more solid than the stock one still but not a permanent piece.
                    IMG_6239
                    went to the local ladies craft store and grabbed some foam and did this:
                    IMG_6243
                    The zap strap will probably not be staying, I'll get a huge worm gear clamp or something, but for now a pair of jumbo zap straps work well. ECU sits in there good, 2 layers of foam made a good snug fit.
                    seems like every day is a trip to the parts store for some small thing, but I'm making progress. I know theres not much to see but theres a good amount getting done. I keep changing my mind on how to do things, and when I do I stop the portion I'm working on and figure out the changes before actually crimping/soldering/cutting. As I get closer to finished the faster it should all go.
                    on a slightly different note I think my deadline is well dead. My buddy's most likely going to drive his dads 201x (haha not sure) Mustang instead of his fox body. My car which would be on stock wheels will kinda be out of place without his factory looking-ish Mustang there. So I'm kinda demotivated to get the car finished by then. I suppose the silver lining is less rush and stress which result in a better end result. I can enjoy the wedding and surrounding festivities a little more too I think...
                    anyway I'll stop rambling and go do more wiring
                    • hey man just browsed through your whole thread again, is that large piece on the right of your trans mount your engine subframe from grannys? If so im hoping mine is similar when I get back to the states. Two more months of deployment lol.
                      • yes it is, its the engine cradle. it bolts into the factory subframe and the engine mounts bolt to it.
                        mixed reviews on fit, mine fits well but it also been installed for a while (I bought it used) a local guy bought one and his doesn't go in as easy...
                          Yeah mine fits good, mines been running and driving for awhile though. I bought it with the motor in it already though. Upon return will be the first time the motor has been outta my car so I will get to see the actual mount. Hopefully I can figure out something to make it sit lower.
                          • Originally posted by LaMaR- View Post
                            lemme know what you come up with! from what I see theres literally no more room, the oil pans highest point is almost touching the steering rack. Way I see it is a few options and none are simple.
                            1: dry sump, might next you maybe an inch.
                            2: custom tubular crossmember that relocates the rack (though I suppose that could be done to the stock one as well) this way is a lot of work as well as the change in steering geometry (bump steer!!) but the FD Ls kits deal with that.
                            The other note is the fox oil pan sits just higher than the subframe, engine goes any lower its now in danger of a strike.
                            If i had the skills/time/budget I would probably do option 2. tubular subframe may even stiffen up the front end more....
                            any who llloooooonnnnggg time since an update (ok its been like 2 weeks) so here we go
                            been listening to Manchester Orchestra lately, mainly Means Everything To Nothing but Simple Math has also had a spin. Just very passion filled raw kind of sound, and his lyrics just peak my interest.
                            So the thing with wiring is its very hard to jump into for just a few minutes. So I've been needing to dedicate an entire day or evening in order to get anything accomplished. So after a seriously long weekend and a few late weeknights its pretty much done!!!
                            so took the engine harness
                            IMG_6244
                            gutted it like a fish. Ford makes all their harnesses (or they did back in '94) for all options so this m/t harness has auto wires and any other option the car could come with pre-wired. So all that junk came out as well as the emissions junk.
                            IMG_6250
                            So much better
                            (lol can't even tell)
                            I took the time to change a few things tho
                            The SPOUT pill for setting the timing used to be on the fender of the mustang, but I put it where they go on fox's
                            IMG_6251
                            much more convenient. My only fear is that the rest of the spout is shielded so if its a problem and I'm getting interference I will shield the re-located wires as well.
                            also relocated the MAF and IAT sensors
                            IMG_6252
                            as well as the 02 and transmission wires (no pic tho)
                            the completed bulkhead connectors
                            IMG_6253
                            then I made another stop at the race car candy land store
                            IMG_6247
                            but after I left I realized I should have grabbed another set of those power wire boots, I used these ones for the rear cut off switch. I want some for under the hood as well.
                            also ATE Typ200 (cuz it was cheaper than blue, blaming you american DOT law thing)
                            IMG_6257
                            also got this, because I love these things and it was $3
                            IMG_6254
                            then the wallet started to hurt...
                            IMG_6258
                            bought the last of the wire I needed (well until I ran out of 8 gauge) we have black 1/0 and ring terminals and heat shrink, 4 gauge, terminals, heat shrink, and 8 gauge, terminals, and heat shrink. Also a quick disconnect for the ignition switch.
                            And I pulled the trigger after much research and little math on what size master to use for the clutch. Went 7/8ths, which is supposed to be quite ideal.
                            IMG_6264
                            finished up the battery area, well minus the box for them. Going to build and get one welded, but all in good time.
                            IMG_6245
                            this was getting out of hand... so I made it prettier (only took like a week)
                            IMG_6265
                            IMG_6266
                            still have a little more tiding to do, but the wipers aren't working and neither are my head light motors, so some de bugging will have to occur.
                            IMG_6267
                            got me a passenger seat finally. Well technically I still have to pay for it lol. Need to fab a mounting bracket for it and buy another 5 point belt.
                            The day this things runs I'm booking the windshield appointment. Its still going to be madness for the next 2 weeks at least doing all the small things. But to have the lights and things working is a huge motivator!
                            • Nice progress! I'm hoping to have a few less relays than you do when I'm done, why do you still have so many?? It turned out clean nonetheless! If you end up needing headlight motors I was told mine are still good but I don't need them because I'm going to convert mine to some sort of manual setup.
                              That engine harness is looking mighty tidy, I'm looking forward to knocking mine down to that status
                              For hood height clearance you can mill the stock intake down (on the gasket mating surface), but I don't think there's more than a few tenths of an inch to be gained before you hit the valve covers. And on my SN95 oil pan I think I have a little more clearance before it hits the rack or subframe, but I haven't looked down there recently so I might be wrong. I would think modifying the engine mounts (between the granny's kit and the engine block) would be the easiest since they're cheap to replace if you mess up.
                              • Ya I have quite a few relays. The wipers take up 3 and the power windows take up 2 for each window. Headlight motors also use 2. If I were to ditch the street legal thing and run bare minimum I could probably have it down from 15 to say 4 or 5.
                                Hood clears as she sits, so not gonna alter anything. Though it's close with the gasket in place.
                                And regarding the engine placement, there's a cm or so separating the rack and pan. Engine needs room to pitch under load so I'd say it's at the limit. Short of a custom pan (maybe one day lol) it's not going anywhere. But for me I'll honestly probably cut a hole in the hood to fit a better intake before finding ways to lower it..
