Nissan Thai-Thai
  • Originally posted by phet_fresh View Post
    thank for all comment
    Yeah! Engine swap to V8 and RWD conversion.
    so How is going there? paste me your build page!
    RWD!?
    Instagram : @SHMVNY_GVNG
      Not that good, mercedes is getting sold due to financial issues. i have a little project with the EK9 civic. but nothing fancy yet! hope to come down to thailand again next year. maybe january or february. i will give you a visit again then
      Visit Bagriders.com for the best deals on Airride suspension.
      Stbk123 - Instagram.
      ViolentClique
      • Originally posted by mikey G View Post
        RWD!?
        will update here!
        Welcome man!
        https://www.instagram.com/phet_fresh/
        • Here is more update, about RWD concersion.
          The rear suspension and LSD differential from skyline R32.
          I cut some frame and build the new chassis for mounting the R32 rear suspension. It's almost finish, left the upper shock mounting.
          • This is amazing! I never thought someone would rwd swap an altima. Great work!
            [CENTER][url=http://www.stanceworks.com/forums/showthread.php?t=66924][color=red]e28 build thread[/color] [/url]
            [img]http://i.imgur.com/hNTlNvf.jpg?2[/img]
            Instagram: [url=https://instagram.com/divingboardlord/][color=red]@divingboardlord[/color][/url][/CENTER]
            • Originally posted by Robitussin View Post
              Thank man, will keep you update.
              • I here the motor came, it's 3uz
                the hard thing is 3uz was lock by immobilizer key and the throttle be electronic.
                My plan is swap the wire harness to 1UZ , first I have to start the motor with the cable throttle and wire harness of 1UZ.
                there are some connector was different. The shock sensor, I use of JZ instead and the connetor of ign-coil. I swap only connector by the same terminal.
                The transmission also chang to manual. I choose Mitsubishi Triton cause it's cheper from Toyota, but it had same flange as Toyota.
                And the crank case need to change to front crank style.
                • Finally I could start the motor 3UZ with the 1UZ ECU their wire harness.
                  So much love the V8 sound.
                  • this build is amazing i absoluetely cannot wait to see it finished. I've been stalking this on instagram for a while now..so much awesome
                    95 ucf20. static, flatbelly, 18x11 18x12.5 lots of camber.
                    be my internet friend on the gram @thisisdalton
                    • This shit is BANANA'S!
                      • Wow this is a whole nuther level of cool. RWD in this case is gonna be the bomb!
                        • Hmm. 3uz is similar to my power plant. 1uzfe. Trying to source a trans for mine lol.
                              Originally posted by TruTaing View Post
                              Thank guys for the comment!
                              This should be a year project, will try my best.
                              • Hello guys! Clutch just arrive a month ago.
                                I had bid the single carbon clutch ORC from Yahoo.jp.
                                IMG_6452
                                It's EVO VII-VIII clutch, the work with my Mitsubishi transmission.
                                Yeah! I have a lot of work to do. Let check it.IMG_6454
                                First the diameter and the bolt hub is extreme different, and the starter gear also
                                IMG_6466
                                IMG_6467
                                But the starter gear is not a big deal, just remove from the old flywheel and lathe to the EVO flywheel
                                IMG_6518
                                And the hub, I lathe it and welding all the hole with the hardest material.
                                And welding the stock spacer plate to the fly wheel to make it hard more, the result is below
                                IMG_6521
                                IMG_6523
                                IMG_6524
                                IMG_6525
                                And the last for the clutch issue, the bell housing.
                                Making measurement
                                IMG_6532
                                And integrated the both bell, and measurement again
                                IMG_6546
                                IMG_6548
                                It is a little long, I will lathe it short and welding, tomorrow.
                                Lastly! after I tried with it and I also shoot few photo.
                                It's so beauty clutch, thought.
                                carbon_single_2
                                carbon_single_3
                                carbon_single
                                Enjoy your coffee
