I need help stretching!
  • I need help stretching!
    I currently have 265/30/22 on my 22X10, but I want more stretch. The only problem is having 22 inch wheels my lowest option is 235/30/22 OR 245/35/22. I really don't want to look like I'm on rubber bands, I need some rubber, so I'm unsure what to do at the moment.
    I am leaning towards 245/30/22, I do want a bit more stretch then what I currently have, I am just afraid with a car as heavy as mine I'll fuck shit up. What are you guy's inputs? Help me out please.
    Here is what 265/30/22's look like before the drop.
    Here it is with a drop.
    235s!!!!!!!!
    im running 225's on x10s and its a good amount of stretch
    but that sucks they dont make anything that narrow in 22's
      Yeah, kind of limited with 22's. =/
      Maybe I should do 245/30? Thing is I cant find any pics online to see what it looks like. FOOK!
        IMO ..your stance and setup looks great.. if you want some extra stretch then go with the 245/35/22 ..thats should look decent and the tire has about .5" overall height difference soo like .25" extra on the sidewalls. The 235 is a smaller tire and the sidewalls are smaller also....22"s on rubberbands can't be comfy
          Where can I find the thing that tells me exactly that. Like the overall width, height etc.
          By the way, i can get 245/30's for for like 80 bucks cheaper per tire then 245/35's. :/
            and you can use mm to inches converter to kinda estimate the tire size - to - rim size...kinda give you an idea of how much ur gonna stretch
            Do a quick conversion: 1 millimetres = 0.039370078740157 inches using the online calculator for metric conversions. Check the chart for more details.
              The thing is I want to run more agressive adapters for more poke. So, 245/30's would help but I am not sure if I should sacrifice poke for grip. Hahah, can't believe I'm asking this here on SW!
                Ur pretty dayum flush now...so how much more of a spacer are you planning on running?? What im getting @ is if your going to get a bigger spacer then you'll prolly be dialing in more camber = less contact patch ...plus a skinner tire...well there goes more of your grip... but sheesh with a 10" wheel how much more grip can a person really ask for
                  Thank you! Found a faster one here - MM to Inches along with that fractional conversion chart.
