Spacers, Lugs, Locks, 3 piece hardware and Custom Adapaters - We've got you covered
  • #16
    Awesome... Ill be hitting you up soon.
    • #17
      ohh la la. You already know ill be ordering the studs from you soon, now i might have to add some 5mm spacers for the front too... We'll be in touch.
      www.stateofstance.com
      The unofficial Work Wheels whore in the making
      • #18
        Just have a quick few questions. I have some new wheels coming in. My car is 5x100 with standard wheels studs. The wheels are 5x120 but are coming with adapters. Dude selling them has a VW so they are coming with lug bolts instead of nuts. The question is what size acorn nut will fit into the adapter allowing me to bolt the wheels up to my car? Do you sell them? How much? For thread pitch purposes, my car is essentially a Subaru.
        SAABaru.
        IvyLeagueEast
        • #19
          The problem you're going to have is that the adapters are built using a 14mm bolt spec but your car (i'm assuming) has a 12mm stud. How thick is the adapter? Are you sure your studs are short enough? If they are you are going to need to run a tuner type nut to make sure that the adapter gets centered on the stud. Also you'll need to find out if the adapters are machined for cone or ball seat. Feel free to give me a call if you have any questions.
          Rotiform Refurbishing Service
          Rotiform Custom Powdercoating
          Check out the Rotiform daily blog on Facebook
          • #20
            We will be picking them up tonight. I will give you a call tomorrow with all of the details. Thanks for your help.
            SAABaru.
            IvyLeagueEast
            • #21
              Originally posted by Pablo
              so is it a subaru or the saab in you sig? one problem will be if its a suby, the hub bore will be smaller than the vw hub, if its a saab, it wouldnt even clear the hub because the adapter was built for the vw (57.1) and the saab is (65.1). not to mention the saab is 5x110. regardless of the car you will be basically getting non hubcentric adapters or adapters that dont fit at all. also all bmw wheels are cone seat, so if the adapters are from a reputable co. they will be cone seat.
              The car is a SAABaru. Essentially it is a WRX wagon.
              SAABaru.
              IvyLeagueEast
              • #22
                Cool - look forward to hearing from you. If the adapters don't work out or can't be modified to work I'll give you a good deal on a replacement set.
                • #23
                  Sounds like a good plan.
                  SAABaru.
                  IvyLeagueEast
                  • #24
                    Brian, we have to talk about some stuff for my new set.
                    I've completely reworked what I'm doing and would like to know if I do as you mentioned and make this work
                    Oh, and, I have decided on a potential full respray instead of just painting the wheels.
                    I used to be famous.
                    somewhere between I want it and I got it.
                    • #25
                      A little "RotiPorn" for everyone. Custom adapters built to my specs by Brian and his team. These little gems were dropped in the mail today. Machined to the mm thickness I need. Here's hoping I measured correctly. Brian's Photos.
                      Thanks again Brian. It was a breeze working with you. Timely emails and phone calls.
                      Mr. Belvedere
                      • #26
                        That is so sick TheNeek. Are you the same Neek on SL? and VSC?
                        Anyways,how about a quote for the exact same thing for my 08+ Scion XB?
                        13mm spacers, 5x114.3, 60.1 bore, 12x1.5
                        Thanks!!!
                        • #27
                          very nice guys, great work!!!
                          Shyne~Fitment Done Right---Your #1 socal fender roller
                          • #28
                            Thanks!!!
                            PM sent
                            • #29
                              Thanks!!!
                              If you want a bolt on spacer we'd have to do 15mm to allow room for the fastener heads when bolting onto the hub face. Can you run 2mm extra?
                              • #30
                                Yes, I can go with a 15mm bolt on spacer. Just as long as it's hubcentric, 60.1 bore, 5x114.3, and has a 12X1.5 thread pitch.
