ok serious question.
my above mentioned e30 m20b27 is choking pretty bad for some reason. i have recently replaced the distributor system and lines, had the MAF system tested and cleaned, had the fuel pump tested while replacing some worn fuel lines, replaced the throttle sensor and had the throttle body cleaned, and had my idle adjusted. after all this it is still hesitating under load and sometimes feels like the engine is not getting enough of something. my next train of thought was that my throttle cables were screwed and that my throttle position is being fluctuated while under load.
has anyone ever replaced throttle lines in an early model e30, and if so, was it a pain in the ass??
any advice would be greatly appreciated.
