Fabel's Fab Fable
  • Fabel's Fab Fable
    It’s time to bring back an old friend to the FMU blog. Like it or leave it, Frame Bangin’ Fabel is back for a little more TLC.
    For those of you who don’t know Fabel, it’s owned by Miles. If you’ve immediately cast your opinion on the man based solely on his car, well, you’re missing out. Even one conversation with him will have you laughing, crying and everything in-between. He’s a people person, and is one of the most sociable people in the local scene. Everybody who knows him, loves him. The same doesn’t go for his car, though. Sporting a set of genuine Work Equip 03 wheels and a drop that’s entirely static, his extremely low Miata has a good deal of both friends and enemies. We know this firsthand, thanks to our YouTube video that we put together when we last took his car off the lift. You wouldn’t think that a video with Yakety Sax as the music would be our most-viewed video ever, but it is. And the comments never stop; some in favor of the car, some not. Either way, Miles and Fabel are dedicated to what they’re doing, and so once again, his car finds a place in our garage.
    By the way, in the two pictures below, this is what Fabel looks like when the lift arms are bottomed out. Yes, it requires some wood blocks and a flat floor jack to even get him on the lift.
    There’s nothing too extreme taking place at the outset of Fabel’s latest round of work. In fact, we’re actually about to do something that you definitely weren’t expecting — that’s right, we’ll be *fixing* the Miata’s body! After mounting a rearview mirror to his passenger fender and removing his radio antenna, Fabel has two rather large holes on the passenger side of the vehicle. So, it’ll be up to us to patch the holes and clean up that side of the body a little bit. He’s elected to fill the holes with metal, so today we’ll be looking at that job, from unpatched holes to patched-up sheet metal. First, since we’ll be welding in some new metal, we had to shave the paint from around the edges, creating a fresh, bare metal surface that will be much better for welding.
    From there, we measured the holes’ sizes and cut out new pieces of metal that will fit the gaps as closely as necessary. The MIG welding will fill in the rest, but the closer you get to a perfect fit, the less work there will be in general.
    And now it’s time to get down to welding. After laying down a welding blanket to cover the other parts of the vehicle, we set about using our MIG welder to tack the new body metal into place. With the tacks complete, we set about filling in the metal wherever we needed to. Since the Miata’s sheet metal isn’t exactly thick, we have to go slowly with the welding, or else the excess heat will warp the surrounding metal, and no amount of fresh paint will cover up flexed body panels.
    With the replacement metal secured to the body, it’s time to grind down the metal to a smooth, even finish. If you’ve done your welding right, the metal will be nearly uniform as you grind down through the slag, meaning the welding has fully penetrated and connected the new and old metal. A couple tiny little spots in the metal here and there will be fine, but as we said before, the more effort you put into it before having to use body filler or primer, the easier the remainder of the job will be.
    The filling of the body holes went well, and now we have two smoothed panels waiting for the next step in the body work. However, while we have it on the lift in fabrication, we’ll be knocking out a few more jobs, since it’s not exactly easy to maneuver up and down the various inclines we have at Fluid MotorUnion. Our next bit of fab work will involve our favorite topic — exhaust! Fabel’s exhaust has a couple low points, one of which is his resonator, and it’s been dented in from being repeatedly smashed into the ground. After a bit of detective work, we’ve devised a way to tuck his midsection even further into the vehicle, once again making his steel-reinforced frame rails the low points on the car.
    Stay tuned for more Fabel content coming your way! We also have a whole slew of other topics to bring on board as well, so stick around our blog and take a look at some of our other projects. Have a great start to your week!
    www.fluidmotorunion.com
    www.stanceworks.com
    Originally posted by Oxer
    I'm overly excited to see a little bit of body work being done!
    IG: ashtonlafleur
      On Frame Bangin' Fabel, no less! The one car I thought I'd never see us doing body work on...
      Goes to show you that Miles is full of surprises! Just wait until we start moving into the more hardcore work. It's going to get interesting, to say the least.
      www.stanceworks.com
        Miles is a great guy, met him a couple times over the years.
        Crazy car is crazy. Love it.
        IG: @dubsesed
        "All is fair in love and low"
        Lowered Values
        PVW 5/15
          Yea, I definitely wasn't expecting that.
          IG: ashtonlafleur
            This all better be happening so he can drive it to SoWo...
            Follow Me On Instagram! @jvc8790 #jvcphotography
              Ooooh, you'd have to ask him about that. Not sure what his SoWo plans are.
              www.stanceworks.com
                I had no idea things were underway.
                without doubt, I will be back to this thread to repost how unbelievably happy I am.
                  You goin to SoWo?
                    short answer, yes.
                      short answer, yes.
                      This made my day. <3
                        short answer, yes.
                        Yay
                        IG: ashtonlafleur
                          Can't wait what you guys do with this "dirty roadster"!!! Fabel always talks quality about work you guys do! So far I love everything that was done to it ! But you have to get the car on the lift to fully appreciate the craftsmanship!
                          Ps: FABEL is to scared to drive the miata to SOWO! :P
                          ///M3 drivers have no friends! -Jeremy Clarkson....
                            Fabel cant wait to see you at sowo motherfucker hahaha
                            I dislike Byron.
                              ^ , not only to Khalil, but to everyone posted.
                              I will be at SOWO, but don't think my roadster will be. there's a few reasons, but foremost is I want to respect FMU in every way possible & not put any pressure on the crew to complete the car by a specific time. they are wonderful to work with & at the very least, I don't need to be another jerk coming in there shouting not only towards making very custom work happen regardless of difficulty, but then to add a time limit as well?
                              naw I won't conduct myself in either of those ways. I'm classier than that, they've already been given enough headache by me asking for some very unique pieces to be fabricated, & I have too much respect for the crew always lending a hand towards making dreams come true (& be safe while at it).
                              also, I appreciate any of you even caring about my car - it humbles me plenty!, but unless I had about 2wks. to make it down there one way, the car just won't handle the drive. I've already started saving up all of my vacation time at work so that I can use it next year for this exact purpose. I should have 16 days collected by the end of 1st quarter for the following year, & you better believe I will be taking my silly lil slamster. thinking of leaving it with a fellow SW member if there is any local & flying back down to scrape back to Chicago.
                              this car really is a lot of work to pilot even outside of the incredible fabrication that is far from over.
                              another thing to remember is, even when I scraped to H20i, I had been sleeping in my car each day. that was 9 days & only 2 showers at the truck stops that had them available. my money is very tight & 9 hotels there with another 7 back would rack my credit card up well over $1k, besides gas & if I lose work days.
                              FABEL uses ingenuity over dollars in everything that he does, & so I shall take example from his successes & live the same. SOWO 2014, lol I'm already preparing.
