HYPETODAY // '89 Mercedes-Benz W124 260E
  • #31
    Awesome read...all the small details make the car what it is in my opinion. Those OZs and that Nardi wheel will look so good man! What are you planning on to get lower?
    • #32
      Great work so far man, can't wait to see the end result!
      Ol Dirty Bastard - RIP
      Photo by Alex Dooley
      • #33
        thanks, guys!
        at first i will change the original spring rubbers. which are available for this car in 4 versions. depending on the equipment, mercedes has previously installed differently thick gums. i get the thinnest. which again makes about 2 centimeter difference. because of the new wheels, also the rolling circumference is smaller. then we'll see. i need also shorter shock absorbers. we will make some new and shorter ones. unfortunately i'm still waiting.
        HYPETODAY // DTM MEETS JDM - The #W6666 project
        • #34
          If you manage to do that (the short shocks), I would like a set of those too
          Lucas
          Originally posted by LCG
          • #35
            okay. if you can't wait: http://www.ebay.com/itm/YELLOW-DPS-C...-/190827598263
            • #36
              Use 1995 Ford Ranger 2wd 4cyl front shocks for the rear of the w124. Comparison shot:
              Sent from my SGH-T959V using Tapatalk 2
              Instagram: @Eurow
              • #37
                Ah those ones. Couldn't find them anymore last time I looked. But thanks for the link!
                Oh btw: are you sure? because I think the coilovers will not work as the top linkage in the wheel well is too weak to hold the pressure
                EDIT: Forgot the camberplate. Never mind
                @MikeyRa:
                That's great! I'll might try that.. And then use E36-shocks in front....
                Lucas
                • #38
                  there is something in germany.. it's called tüv!
                  • #39
                    those work on a benz huh ?
                    C280 Build Thread
                    C43 ///AMG Build Thread
                    E320 Wagon Build Thread
                    Follow me on Instagram:@SD_210
                    • #40
                      super small update.
                      today I picked up my car. a nice difference since the start and now. i hope that on the weekend the wheels can be mounted. let's see if i have time.
                      it's a long way, there's more to come! hope you enjoy the thread!
                      • #41
                        Originally posted by loekaaz View Post
                        @MikeyRa:
                        Or R129 upper strut mounts for the front.
                        t
                        The sure do, I lay rear diff with these on the rear
                        Instagram: @Eurow
                        • #42
                          You need the Sacco Bretter side panels...
                          Lucas
                          • #43
                            nooo... less hidden surfaces - less rust. i also do not want to drill 11 holes in my sill for the cladding.
                            • #44
                              You do not need to drill anything. You can use the original holes. At least, that what the PO of mine did.....
                              So it should not make any difference compared to the original situation..
                              Lucas
                              • #45
                                Looks sharp! I really like the shift knob/boot combo you made. Can't wait to see it with the wheels and coilovers.
                                Just a question- In Germany do you get to choose if you want the long "traditional" plate or the ones you have on now?
                                Instagram: @HOONResponsibly
