Results 1 to 8 of 8
Thread: Water Spots on Windows that wont go away
    Oct 2012
    Cape May , NJ
    9
    Default Water Spots on Windows that wont go away
    One of my windows on my car has some water spot that I cant just get rid of. I have tried every glass cleaner I can get. What can I use to get them off. I heard a fine steelwool will do it as well as a mild clay bar but am kind of leary to use them on glass
    Jun 2011
    Sequim WA
    7,694
    white vinegar will do it as well as amaz glass polish.
    Oct 2012
    Cape May , NJ
    9
    Okay I will look around for the glass polish if I cant find it I will use the white vinegar. should I mix it with water and if so how much?
    Jun 2011
    Sequim WA
    7,694
    I used straight vinegsr applied with a mister bottle. Try yo keep it off paint. Its not harmful to paint but it ruins a fresh wax job.
    Jun 2009
    Pittsburgh, PA
    1,734
    #000 or #0000 Steel wool or an agressive claybar will not harm glass. More often than not, I find myself using a regular straight razor blade for nasty water spots on windows.
    Get some Griotz fine glass polish. It contains Cerium Oxide which is a very fine glass polish.
    Mar 2011
    Spokane, WA
    810
    Yup steel wool. It will not ruin the window
    Steel wool.
