Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: How to Calculate Offset after Lip and/or Barrel Change
  1. #26
    Saved for later!
  2. #27
    t.han Guest
    oh my god, there is a chart! SAVED
  3. #28
  4. #29
    Default Confirmation
    So I purchased BBS Rs faces (329) which are 17x8 et0.
    According to previous owner they came with 1.5 lip and 6" barrel. I would like to put 5" lips on the rear which according to that chart puts me at 17x11.5 et - 44.
    Can anyone confirm that?
  5. #30
    Jun 2013
    Portlandia
    1,768
    Quote Originally Posted by Ls1s13 View Post
    Are they sandwich mounted currently, and if so are you going to leave them sandwich mounted?
  6. #31
    Quote Originally Posted by Oh Damn, it's Sam View Post
    I just purchased the faces by themselves from a fellow member. I assume I will sandwich mount them. I'm new to building 3 peice wheels so you'll have to bare with me.
  7. #32
    Jun 2013
    Portlandia
    1,768
    329s are sandwich mount from the factory, IIRC, but they are RSs, so who knows what's been done to them over the years. Still, they'd have to be sandwich mount for them to be 8" wide with the lip and barrel specs you were given.
    If you choose to sandwich mount them, then the specs you posted above are indeed correct.
  8. #33
    OK and if I choose to go with a 5.5 barrel and the 5 inch lip my offset would only get more negative right?
  9. #34
    Jun 2013
    Portlandia
    1,768
    Correct. If you subtract 0.5" from the width of the barrel, your offset will change by -6.35mm.
