Hi, I'm Amir and this is my '76 911S track car.
2 years ago I decided to sell my turbo Miata. It was a great car, but I decided I wanted a European car again. Originally the plan was to pick up a Boxster and turn it into a Spec Boxster. During that time I took a ride in a 911SC and decided I had to have a 911. After some searching I found a 911S that was a "turn key vintage racer". It sounded like a good car and I decided to buy it. 25 hours later I drove from CA to NM and came back with my dream car.
Here she is on the drive home and at her first meet.
After fresh fluids and quick once over I took her out to Buttonwillow for her first track day.
And again at Streets of Willow
The I put it on a lift and found out that the previous owner was a jackass and everything needed to be replaced. I went to work and in the mean time picked up some aero parts. After a couple of months and lots of parts underneath being replaced the car was ready to go again.
I wasn't a fan of the Remotecs and the narrow body, so I put on a set of CCWs with Hoosiers and 930 flares.
That brings us to today.
Here is the current list of modifications
1976 Porsche 911S
Horsepower 240
torque 230 ft lbs
Weight 2100lbs
Engine and Transaxle
2.7 liter engine Porsche flat 6, case machined for case savers
Nikasil Cylinders
9.5:1 High compression JE pistons
Solex Cams
40IDA Weber carburetors
Magnacor Ignition Wires
Petronix ignition
Back dated '74 Porsche headers
Custom Sebring Exhaust
915 transaxle with a 7.31 r&p
Suspension and brakes
RSR Front Struts with Coil over conversion
Rebel Racing Custom body and valving Bilsteins with coil over conversion
Swift Springs (Extreme Time Attack contingency sponsor)
Tarret Engineering front Sway Bar
Tarret Engineering Monoball Camber Plates
Weltmeister adjustable rear sway bar
930 Tierods
Bump Steer kit
Elephant racing polybronze control arm bushings f&r
928S Front Brake kit and 930 Rear Brake kit
Stainless steel brake lines
Motul RBF600 fluid
Porterfield rs4r pads
Rennsport Systems Master Cylinder
Wheels:
Track - CCW Classics with Hoosier R6s
Street - Hartmann 3 Piece Twists with Hankook RS3s
Interior
Stack racing gauge Cluster
Autopower Roll bar
Bride Low Max
Sabelt harness
Key!s Racing Steering Wheel
AEM UEGO wideband
Bob Ashlock CHT Gauge
Hargett Precision pro shifter
Exterior:
GT Racing Carbon Fiber roof
TRE Motorsports 964 Turbo Front Bumper
TRE Motorsports 964 RSR front lip
custom front splitter mounted to the frame
Custom Canards (not installed)
964 turbo GT Racing Fiberglass Rear Bumper (not installed)
GT Racing 3.8RS deck lid with Banana wing
Rennspeed Turbo Flares
Exterior Kill Switch
9K racing Tow straps
and much more that I can't remember.
I have a lot of work left, an extra set of wheels to provide better fitment. I'm waiting on outers for those, and there are a slew of other parts waiting to be installed once I get the time. I hope to have this done in the next few months. I'll post updates here as they come along.
It will be lowered more, but the car has to be functional. I'll be sending the struts out so I can drop it another .5-1" and maintain the geometry. It also looks sky high since there are no skirts, rear bumper, or splitter on the car. It will have a much more finished appearance once I finish the suspension and get to the body work.
