subscribe!
BMW E30 sr20 swap E85 drift build
Just waiting on a set of these Tie rod spacers from VE, (needed to run the E36 wrack, tie rods and E46 lower control arms.
Should have Ar. gas this week, looking forward to VELDING!
New year is throwing a wrench in my gears at the moment, tried to get my DOM tubing today but nobody seems terribly motivated to make that happen before the weekend... Oh thailand
putting a bit of metal back into her, (still waiting on DOM)
recently had some time to add a little strength and caster adjustment to the front strut mounts.
Few more hours on the E30 today
Originally posted by royalife View Postwe need more consistent updates on this! LOL good work sir
More metal...
Front strut towers
Tubes to front frame rail
Tubes to lower frame rail under drivers/passengers feet. *still need to add gussets to a few places on these*
Repair/re-enforce/replace frame rails
Added "sub frame connectors (these basically run wheel to wheel (front to back) along the pinch welds and have a few cross bars) *will be incorporating trans mount and drive shaft hoop in the cross bars*
Sheet metal patch/re-enforcement **as you can see in the pictures rear of the front wheel wells still need some sheet metallove**
E34 complete subframe swapped in along with rear coilover set up.
I also had some time to start on the cooling system, still have to add a few breather fittings/lines before she's complete
