(e36) tires rubbing, need help
  • (e36) tires rubbing, need help
    I have an e36 coupe but the weird thing is that only my front right tire rubs a lot when making turns, the fender is dented a little so that might be why. for additional info, I am running 17" style 44 oem wheels on size 225/60 tires with 10mm adapters in the front and 235/60 with no adapters in the rear, any suggestions? Im guessing i'll just have to roll my fenders, does anyone roll fenders or know any good spots to get your fenders rolled in or near toms river nj? Thanks
    Im going to guess that since your running a 60 series tire you are stock ride height??
      Or a lift kit...
        are you kidding about the 60 series tire? that's a small truck/suv tire.
        025garage
          get smaller tires.....Like a 40 or 45 for starters and why are you running adapters?!
          HoodRatStatus
          Instagram @looneylow
            nvm im srry i meant 235/40 and i have the problem solved...turns out im uneven by a few cm's
