Page 1 of 9 123 ... LastLast
Results 1 to 25 of 202
Thread: IntroDoucin tha 71' Bavaria
    Default IntroDoucin tha 71' Bavaria
    Long time listener, first time caller....
    First off, some damn nice cars in here, keep up the good work guys!
    And now to introduce my project.
    History.... (you do not have to read, but it is entertaining)
    Basically I picked up a Bavaria up in Oregon a couple months ago.I traded a 1994 Cherokee for the car.
    All I knew was that the car was in Portland, OR and I was in SF.
    The car had been sitting for years and it ran fine when it was parked. Me and 3 buddies drove up and planned to drive it home.
    When we got there, we found a broken fan clutch and leaky fuel lines so the engine could not pump fuel. We fixed that after 3 hours in 112 degree weather. We are on the road!
    The trip: Took 3 days.
    Gas was first.
    The very first thing that went wrong less then a mile away from your house was the throttle cable. There is a spline that was stripped so we fixed that at some gas station. It was so hot (i think 110) and a guy gave us some free waters and then another mechanic came by and asked if we needed anything. We did need a spring to hold the carbs shut. So we got that and the stripped spine fixed within 2 hours.
    Code showing his appreciation of H2O
    We started to head down the road to "horsepower freaks" to go and visit. We got there and hung out for a bit....
    but when we were walking back to the car, we noticed it was dripping from the transmission pretty bad. So we pulled into a shop real quick and tightened the tranny bolt. People were so nice there.
    As we started to head home, we pulled out of the driveway and the car shut down. So after a couple hours of trying to figure out what it was, we realized the fuel pump was clogged, so we had a spare in the trunk plugged that in and primed the system.Note everytime we had to fix something, we had to pull out about 100lbs of shit out of the trunk.
    It started up and again and we were off. Solid Driving that night! No problems, we were so happy.Minus the heat...
    Ryan
    Me
    11:00pm that night I was sitting in the back seat and noticed the center divide was very bright. What could that be? Police? shit! Nope! We were on fire.... We pull over, through everything out of the car as quick as we could and threw it onto the shoulder. Pablo Saved the bavaria and put out the fire. We were 20 miles south of Eugene, OR on I-5. We didn't know that and we tried to call for police but only my phone had battery out of the 4 we had. So after 1.5 hours, a tow truck found us and hauled us to Eugine and dropped us off in a neighborhood. We walked to a motel, and finally got some sleep since we were up from 8 the previous night when we left SF.
    The next morning we looked at the damage. Note we have no money or phones. We found a little german shop we pushed the car to.
    Yes, Pablo had a chance to ghost ride ride it
    We checked out the damage real quick. They needed the lift and helped us so much by just letting us check it for a couple of minutes We must have drank their whole 5 gallons of cold crisp water. We were so dehydrated.
    To our surprise...
    The drivers side rear brake must have been rubbing and caused so much heat it caught fire. It split the brake disc in half. So we pushed it again down the street and jacked up the car using the oem bmw tools, and removed the brake rotor. bolted the wheel back on. Thankfully the fire cause the whole caliper to seized so we didn't have to bleed the system. We also managed to get distracted by lighting a squished squirrel on fire.
    We headed off and no problems occurred until we got to the State park by the CA border. We noticed the passenger side rear wheel was very hot. So we jacked it up, and pulled the brake disc on that side too. SO we had no rear brakes.
    And back onto the road...Until....Problems!
    We started to get to Eureka,CA. Around 11:00pm. Then realized we had NO BRAKES! We downshifted to a roll at an exit and found ourselves in an abandoned denny's. We had no idea what was going on. After 2 hours we found out that the rear caliper finally un siezed and was leaking causing no pressure in the system. So we found a fence and snapped the tip off to fit it in between the calipers where the rotor would be.
    That seemed to work. The next 6 hours we headed home with 1.5 brakes. The right front work way to good and the left front barely worked.
    We did get home finally and I left it alone for about 2 weeks.
    I Then drove it to my friends shop where I was going to overhaul everything mechanically.
    Things I've done:
    The old tranny was leaking to much for my liking so I decided I will somehow put a newer BMW 5-speed tranny in it.
    -Put 5-speed Getrag 265/6
    -New Shift linkage plate (e28)
    -New clutch
    -Machined Pressure plate
    -New rear main seal
    -New pilot bearing
    -Had to fab up a cross member for the tranny
    -Shortened and balanced the driveshaft
    Brakes:
    -New rotors
    -New Calipers (2002 tii front calipers)
    -New Pads
    -New lines
    Other things:
    -17'' BBS style 5 wheels
    -Tires
    -New radiator
    -Alternator from e28
    -Sound system
    -Fixed most the lights
    -Another fuel of filter
    -Wheel bearings
    -Exhaust hangers
    -Removed old cruise control unit
    -Adjusted Carbs
    -New fenders
    -New bumper
    -New bumper brackets
    -valve cover gasket
    -Fixed power steering leak
    -Cap, Rotor, Plugs, etc
    So, I have been driving it every day (at least 60 miles a day) for the last several weeks and I couldn't be happier. I love the thing and have so more work to do.
    Next is paint, some interior stuff, and coilovers.
    I'll keep this thread updated as I go.
    -Rick
    May 2009
    Seattle
    4,237
    Epic so far.
    Thats some nice stable you have there on your driveway
    Oct 2009
    London, England
    91
    That's some superb bodgework. Great tale and good luck with the project.
    now that is an adventure!
    Nov 2009
    California
    789
    damn....what a story!
    im jealous though, the thing looks great!
    Aug 2009
    Las Vegas
    14
    Such an amazing story! Ha
    And I have a sneaky suspicion that car is gonna be so tight
    Quote Originally Posted by dav3design View Post
    ...I have only just cottoned on to what is happening. lol
    I have a pair of tan headrest for a Bavaria if you interested.. Can dye them.. Have the trunk brackets too..
    Cars gonna be sick.. Can feel it..
  9. #9
    May 2009
    Laguna Niguel, CA
    576
    awesome story and car. i love bavarias!
    2011 Outback 2.5i 6MT #subarubaru - daily/off-pavement adventure vehicle
    2001 BMW 325i Wagon 6MT #daswagoon - wife's #becauseracewagon
    1996 Suburban 2500 TD #superbbourbon - tow bitch/people hauler
  10. #10
    Oct 2009
    New York
    231
    EPIC!!!
    but umm...
    just wondering, but what would inspire such a person (you? or whoever that is) to wear uggs (or shoes of the sort) in that kind of weather?
    LOL and nice gatorade btw.
  11. #11
    Sep 2009
    bay area
    198
    I want one!
  12. #12
    Jul 2009
    Newport Beach
    2,418
    Damn what a story lol. I love Bavaria's, looking forward to updates.
  13. #13
    Sep 2009
    Bend, Oregon
    769
    What a story!!!! good thing you guys know what your doing
    such an awesome car. looks like you have gotten alot of work done so far!
    and the clothing choices for the weather????? ugs really? haha
  14. #14
    Jun 2009
    Pittsburgh, PA
    1,734
    I love Bavarias.
  15. #15
    Quote Originally Posted by Fatandre View Post
    Not mine but a friends.
    Quote Originally Posted by 06impreza View Post
    same color and material as my bavaria?
    Quote Originally Posted by OMG TSX View Post
    EPIC!!!
    but umm...
    gatorade? and the guy with the german made slippers.... thats just normal behavior for our friend Ryan.
    Thanks for the compliments. Glad some of you can see the potential.
  16. #16
    Mar 2009
    Mill Creek WA
    3,468
    hi ricky
    I love the interior. Why'd you pull the front passenger fender? I hope we get to work on ours soon. I'll be watching your build closely. how much for the rebuilt caliper?
    Mr. Belvedere
  17. #17
    Thanks Nick! The interior is my favorite part no doubt! The calipers took about 2 weeks to find. Good luck! I know I grabbed the last one at 3 different places. But, they were about $54 a piece for the fronts, and $30 something for the rears. As for the fenders, I had to replace both of them. The PO must have had a bra on it for years and the top of the fenders were rusted through. :dunno The wierd thing is that there is no rust on this car at all. I was shocked.
    Thanks!
  18. #18
    Aug 2009
    NorCal
    1,398
    uggs? really?
    cant wait to see the car all sorted out
  19. #19
    dude awesome story , car looks awesome, good luck with it.
    Its all about
    "Fit&Finish..."
    Quote Originally Posted by HooWybrow View Post
    I gotta say, I saw this car, and got a boner.
    And, no, it wasn't just the pleat in the pants. It was a full fledged man-love-car boner.
  20. #20
    Oct 2009
    Birmingham AL
    574
    Damn what a trip cant wait to see what else u do to it.
  21. #21
    Quote Originally Posted by Rickysbmw320i View Post
    Pm sent
  22. #22
    Nov 2009
    Las Vegas
    1,022
    great story.... Need MOAR pics of the new setup!
  23. #23
    I will try to get some. It just is scary ugly right now in the front. 3 different colors and an anti-stance setup in the front. here are two to hold you over.
    The fire extinguisher is more of a joke than anything...
  24. #24
    Oct 2009
    New York
    231
    ...look theres a gatorade bottle near the rear left wheel well
  25. #25
    Mar 2009
    Nashvegas, TN
    4,201
    Lookin' good. I'm supremely jealous.
