E36 belly?
  • #31
    If you're that concerned with your undercarriage, fab up a skid plate or something.
    • #32
      Originally posted by Kielan View Post
      "I'm a mechanical engineer"
      Clearly not a very good one.
      yeah sucks i got a 4.0 gpa for my masters and designed and built an SAE baja car. If you want to get into a pissing contest, message me dude.
      i merely expressed a concern and was curious if anybody had any experience with a product since we're all "car guys" and I didn't think i was the only one that would cringe at the thought of rusted frame rails.
      back to OP yes, if it's "mad low" i agree, no coating will stay on any frame rails. Regardless of that, corrosion is still going to occur (which is my point). my question was in reference to moderately low and utilizing a coating.
      Robby
      • #33
        Robby
        yep, POR15 should do the trick.
        BMW e23 build Thread
        • #34
          thanks, that's all i was looking for haha.
          • #35
            But if its low enough to need to be recoated, its not going to help. It's just going to happen again.
            • #36
              agreed. when i hear moderately low, i think bf.com low
              • #37
                • #38
                  damn, i was just looking for pictures of scraped/beat e36 bottoms so i knew if it was as bad as driving an mkv. but now on the topic of rust...
                  thanks for all the input anyway
                  nhoJyauQ/John Quay
                  E36 Vert Build
                  Instagram @nhojyauq
                  • #39
                    IDK my E36 is what i would call moderately low, i would call Mike's E36 moderately low too. Josh's car is very low. IMO it's like lowered (BF.c); Moderately low (Mike's E36); Very low (Josh).
                    in driving my car i can avoid anything that would potentially scrape the rails EXCEPT getting into my work driveway. granted the car isn't my daily but i was just really concerned about having bare metal. That's all LOL.
                    • #40
                      if you are that concerned about rust, build some sort of skid plate that will sit against the frame rails. so only that part will scrape / rust, then replace it when its worn down.
                      there really is no other option, except if you cut them out. but that will leave the fuel / break lines unprotected and would easily be damaged.
                      -Instagram@jdjurhuus
                      Stretchsaurus and Pokemon.
                      • #41
                        Here's mine. One of the frame rail's got a nice dent in it
                        • #42
                          oil pan on my e36
                          • #43
                            what did you manage to hit?^
                            nhoJyauQ/John Quay
                            E36 Vert Build
                            Instagram @nhojyauq
                            • #44
                              you pan sits high enough for the m3 xbrace to be installed right under it.... it came stock on my 95 cabrio, gives me some piece of mind that i would have to replace that instead of an oil pan lol
                              • #45
                                It seems to make sense to add a $20 skid plate and keep your frame rails perfect....
