It's time to sell the e30.CLEAN TITLE It is not 100% finished, though it is a great daily driver and has lots of potential. Could easily be prepped for the track or just buttoned up.
I have owned the car now for almost 3 years and have never had any major issues with it. I would like to have someone who appreciates the car for what it is, plus all the parts that are on it. I have more money in parts then what I'm asking for the car.
Here is the full build thread nothing is hidden
Specs: 256k+ on chassis(odo doesn't work like usual)
Body-
Car is vinyl wrapped white its not perfect but it looks better the black paint that was done by p.o.
few dents here and there, the car is 27 years old
keyless entry,power door locks,power sunroof, power mirrors
late model plastic bumper swap
vented dtm fiberwerkz fiberglass hood
original mtechII spoiler(rare)
mkII rear window spoiler
volvo front lip
euro elipsoids with hids
eyebrows
tinted widows
crack free dash
Motor/Drive-train
Motor has been replaced with lower comp 2.7i. It was built by a member on r3vlimited.com and everything was replaced. Has roughly 6k on sense rebuild
Head was redone, full port and polish all valves were new, guides and seals.
The motor pulls harder then stock m20's. Perfect for running boost:-)
oil change every 3k doesn't burn at all.
Also has raceskids skid plate
No a/c
The drive line has just been redone. New clutch,pressure plate,throwout,pilot bearing.
The drive shaft was just rebalanced with new center support bearing.
Shift linkage also was just rebuilt with all new delrin parts and z3 short shifter.
new clutch slave and master
Suspension/brakes-
ROTIFORM BLQ 17x8 et 20 brand new
wheel studs versus lug bolts
Full xyz coilovers(bc sport equivalent) just different color scheme
ie engineering sway bars 25mmf/22mm r
sparco front strut brace
new front control arms with new bushings
treehouse racing cab's
drilled and vented rotors front and rear new pads new stainless lines front and rear
new master, new booster
What it needs-
Carpet(I will provide)
To complete the look of plastic bumper swap it could use rear add on apron( dtm fiberwerkz)
Black back seats/ also black front seats.
Is lip
If the vinyl bothers you then paint.
So to completely finish the car your looking at say a grand.
Rest of the work has been done. I just need to focus on school right now, and be able to pay bills seeing as I'm not working as much.
Will take 3,500.....
I know it's not a purists e30 but it's a blast to drive.
Thanks
Also car is located in mission viejo.
iPhone via taptalk
Body-
volvo front lip
eyebrows
tinted widows
crack free dash
Motor/Drive-train
No a/c
Suspension/brakes-
What it needs-
Is lip
Thanks
iPhone via taptalk
