the sorta flush nissan missile truck.....PICTURE WHORE WARNING
  • Just went through every page; looks awesome man gives me motivation to work on my project
    • Originally posted by FunfGang View Post
      Simply amazing work, makes me feel like I'm doing absolutely nothing with my swap hahah. Keep it up!
      thanks man means a lot. your a whole lot further along than i am though. i really enjoy your build thread...
      its getting there slowly, within a month a should have a custom trans adapter made by a friend of mine. then the ball will really get rolling
      DRIFT BUILD
      • Originally posted by pejsa View Post
        Thanks man, appreciate it!
        But all the custom work and fabrication you're doing is awesome, plus the thing is going to move!
        E30 V8 Build thread
        Go here be happy!
        Instagram: stuartrussell
        • loving it!!! its weird i had the same color valve covers in the beginning also haha!! keep it up though I'm watching closely.
          I clearly have an addiction to boost..
          • Originally posted by Mossberg500 View Post
            thanks man i actually had an s13 painted the same purple too hahaha
            also i decided that I'm going to be competing in the Top Drift season next year at willow springs with a fellow truck drifter. so root for me
            made a little more room for the monster
            cut holes in the firewall for the shock hoops
            bent the shock hoops (1.25 120wall DOM)
            some very detailed suspension diagrams drawn on my fender
            mock up suspension till i can get my hands on s14 coil overs
            and the POS little welding cart i made today
            should have the truck on the ground late tomorrow
            DRIFT BUILD
            • got a little done in the fucking rain today
              shock hoops mocked in place. just tack welded for now.
              tight fit
              full droop height with stock struts
              gussets yet to be welded
              and the shock top hats are not finished they will have additional tube braces to support them with a bolt in cross bar over the motor tying the shock hoops together
              DRIFT BUILD
              • cant wait to see this done! trying to get my hands on an sr for my s10. hopefully gonna be savage. your giving me motivation
                • OOOOOHHH YEEAAAAAAA!!!! keep it going.
                  • its going
                    so today was a great day, and i got the shock hoops completed!!!
                    check it
                    super tight fit =]
                    welded top and bottom
                    gussets
                    airel view
                    painted the tc rods and hung the suspension again
                    DRIFT BUILD
                    • I'm here because I'm fascinated by fabrication If I tried to do this, the front end would be pointing in the wrong direction
                      E30 V8 Build thread
                      Go here be happy!
                      • how come i missed this?
                        Awesome stuff, tho those welds seem to need a bit more heat. (i'm not professional tho.)
                        -Instagram@jdjurhuus
                        Stretchsaurus and Pokemon.
                        • This build gets better and better. How much of the original truck is remaining?! :P
                          • Originally posted by TruTaing View Post
                            hahaha thanks and not very much at all. most of the cab, and most of the frame oh and the doors
                            DRIFT BUILD
                            • Nice! Great welds, great tubing setup. Now hurry up and put it together! i love this
                              • so i got my wheel adapters today 5x114.3-5x120...1 1/4" wide......3" center bore
                                slight modification
                                test fit
                                will be another .5" of clearance with the rotors on it
                                can you say poke?
                                acceptable angle
                                unacceptable
                                hitting the tc rods
                                plan on running a 215x40 tire
                                DRIFT BUILD
