Results 1 to 5 of 5
Thread: E36 engine help! (noob)
    Default E36 engine help! (noob)
    i need some help. i got a 320i e36 as my first car, automatic (lol) and its sat for a while due to parents being.. well, parents. so i finally got a battery for it after a year and a bit (dont ask) and i started it up. at which point i noticed its idle is strangely high. its only high when its in neutral and park. when i put it in drive its at the normal idle. im thinking maybe its an idle control valve problem? or a vaccuum leak? is this a costly fix? or would it be covered in an ordinary tune-up.
    heres a video
    [ame="http://www.youtube.com/watch?v=f3yy14igFLw"]YouTube - ‪BMW 320I E36 Help‬‏[/ame]
    Jun 2011
    www.statusracing.com
    428
    I would judge it to be the same issues as you think. Idle air control or cracked vacuum line.
    You should be able to adjust your idle on the intake manifold, should be a screw that goes into the IAC box that you can adjust and see if that makes any difference.
    I hope you figure it out
    -Jade
    StatusRacing.com
    Configure YOUR Seat Here
    Tel: 1.480.265.8600
    Email: sales@statusracing.com
    Fan us on Facebook
    Jun 2011
    Sequim WA
    7,748
    I'm betting it's a vacuum leak. I would take a propane torch and open the fuel slightly but dont light the torch. place the torch near vacuum lines and see if the idle decreases. Don't forget, always do this in an open area.
    Jun 2011
    Houston
    7
    Quote Originally Posted by Jlyons617 View Post
    or carb cleaner if u dont have access to propane. Just dont use brake cleaner, it will mess up your o2 sensors. And try to not spray on exhaust and alternator
    thanks alot guys. i had a feeling it was the ICV. BUT i was driving it the other day (on my g1 cause im a boss) and it started revving itself in drive, so it basically drove itself. that was QUITE alarming to say the least. and statusracing i wanna try that thing with the idle anyway, i think its pretty cool. i always wondered wut was under that little box by the intake,
