Page 1 of 3 123 LastLast
Results 1 to 25 of 67
Thread: AccuAir Height Sensors Installed
    Dec 2010
    Grover Beach, CA
    169
    Default AccuAir Height Sensors Installed
    Let's make this a thread for pics, info, questions, and help on installing ride height sensors for your e-Level controller. Feel free to jump in and post pics of your sensors installed to help anyone else looking for tips and tricks! Here's a few customer installs to start:
    B6 Wagon Front Sensor:
    B6 Wagon Front (plate welded for sensor mount):
    B6 Wagon Front Passenger:
    B6 Wagon Front (lower bracket):
    Mike Alexander
    Director of Marketing
    Mike@AccuAirCS.com
    (877) 247-3696
    Dec 2010
    Grover Beach, CA
    169
    And here's the finished result (AccuAir + BagYard)!
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
    Dec 2010
    Grover Beach, CA
    169
    This was for a MKV:
    MKV Rears:
    MKV Fronts:
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
    Aug 2009
    MEL Australia
    23,253
    Hey Mike, Havent happened to do an Acura TSX by any chance? Shortly Ill be hitting you up for a kit for one, but the rear ends have a crazy 5 link rear set up, and although I havent had a great look, I thought I'd ask haha.
    Quote Originally Posted by anth View Post
    Dec 2010
    Grover Beach, CA
    169
    Quote Originally Posted by Oxer View Post
    Jay is on here, running e-Level with his TL, maybe he can chime in:
    http://tl.acurazine.com/forums/showt...=764733&page=8
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
    Dec 2010
    Grover Beach, CA
    169
    Since you have a truck and chassis fab background, you'll be able to handle it no prob lol
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
    Aug 2009
    MEL Australia
    23,253
    Quote Originally Posted by AccuMike View Post
    I have no doubt either, I just remember pulling the rear wheel off and seeing 5 bars holding the hub in place and thought of a jungle gym haha... Four links are so much easier haha.
    Dec 2010
    Grover Beach, CA
    169
    Here's a few more with custom brackets that people have built:
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
  9. #9
    Dec 2010
    Grover Beach, CA
    169
    HAHA yeah, I kind of miss trucks for that reason lol
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
  10. #10
    Dec 2010
    Grover Beach, CA
    169
    Here's a MKIV:
    Rear:
    Front:
    Sorry about the pic quality on some of these! These are just customer installed pics to help shed some light on sensor mounting locations
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
  11. #11
    i am curious as to how these work. the lower arm is constantly moving, so when does it know when to appropriately send the signal to balance the car? i will be purchasing from you guys soon for my upcoming project.
    Quote Originally Posted by Kielan View Post
    BMW e23 build Thread
  12. #12
    Dec 2010
    Grover Beach, CA
    169
    The e-Level controller takes ride height data 200 times per second and simplifies all of the data down to one representation of vehicle height (for all 4 corners) over 45 seconds while driving and over 5 seconds while parked. The controller will then make a correction if the ride height is outside of tolerance.
    In more simplified terms, the e-Level system will keep your car balanced and within height and alignment specifications, but it will not try to correct for every bump in the road, every hard turn, or every hard stop. Adjusting suspension height on the fly for real-time dynamic situations is classified as a "fully-active" suspension system (these are usually hydraulic like the Mercedes CLS). The AccuAir e-Level system is classified as a "semi-active" suspension system because it does adjust based on scenario and circumstance, but not on a real-time basis. This allows for the height adjustments based on load changes (additional passengers, fuel, etc) but combats any irregular changes in normal driving situations.
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
  13. #13
    Dec 2010
    Grover Beach, CA
    169
    Here's a Golf GTI:
    Front:
    Rear:
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
  14. #14
    thanks for the info mike! im an electrical engineer, so its alright with me to get as technical as you can. its pretty close to as what i figured. good stuff. i'm waiting on some feeback to a custom setup i need done, then the next step is an e-level system. i hope to post my setup here by the end of the year
  15. #15
    Hey hey here is my Sensor install on my 2008 Acura TL-S which should be similair to a TSX, first two pictures are of the front and the last is the rear, i will get a better picture next time i get the wheel off. Both front and back sensors are attached to the sway bar, we added a tear drop metal plate used a lock washer to ensure it doesn't get loose from moving up and down.
    FRONT
    REAR (sorry was hard to get a shot showing it connected to the sway bar)
  16. #16
    Aug 2009
    MEL Australia
    23,253
    Quote Originally Posted by vipTL View Post
    Thats awesome, Thanks heaps dude, Makes my life a lot easier haha.
  17. #17
    Dec 2010
    Grover Beach, CA
    169
    Quote Originally Posted by NegativeCamber View Post
    Nice! Very cool, looking forward to seeing what you come up with! Keep us posted!
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
  18. #18
    Jun 2010
    Melbourne AUS
    260
    this guy, full doing reasearch for me and everything <3 u
  19. #19
    Jun 2009
    Boston
    2,234
    I can't wait to contribute something to this thread
  20. #20
    Feb 2010
    Temple, PA
    4,535
    deff be stopping back in here if i end up getting a wagon and bagging it...just looks like so much work...main reason of not adding e-level to my cabrio and just running switchspeed
    Insta Mintyhinrichs
  21. #21
    VW Golf MK4
    What i got so far, i'll post the rear pic this week if i'm not lazy
    Taken from my build thread here: http://forums.vwvortex.com/showthrea...-Rocker-Switch
    Here how the sensor is fully extended and fully compressed on Raceland coilover, Hopefully the Airlift XL doesn't extend more or I'll have to cut a longer aluminum bar
    I had to mount the sensor arm backward to increase the tire/sensor gap when the wheel was fully turned left.
    and here is the other side
  22. #22
    Oct 2009
    Dallas, TX
    4,294,967,248
    Quote Originally Posted by kilimats View Post
    :::::ITSHIM:::::
    qq
    Quote Originally Posted by Jesus Christ View Post
    if "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.
    Quote Originally Posted by Jedidiah View Post
    he speaks the truth.. he doesn't even have the -- -- eyes.
  23. #23
    and here is the rear
    EDIT: the sensor travel was too small so i had to relocate the ball further in the rear
  24. #24
    Dec 2010
    Grover Beach, CA
    169
    pics aren't showing up for me?
    Mike Alexander
    Mike@AccuAirCS.com
    (877) 247-3696
  25. #25
    Your work place most likely filter images from DROPBOX.com
    That's where I host them
