Awesome man. Looking good so far. Now that I see the issue you're running into it makes more sense. I'm not sure if T3 sells that upper hat separately, but its worth calling them up to ask. At worst, you can se a thick metal sleeve over the shaft to space down a top perch that typically is included with cheaper coil sleeves.
Are you using Afco's sleeves or are you going a different route?
