Nice and clean, and a diesel to boot. :thumbup:
Hello, Can i play?
Originally posted by DaRedRocket View PostStyle 5's are a two piece wheel. The barrel cannot be on bolted from the lip, only the center. Only way you're gonna get more width out of those is banding them like Mike suggested.
Those staggered 18's will definitely fetch a good amount whenever you decide to part however.Originally posted by M.Burroughs View PostBBS won't give you lips. You'll have to go aftermarket.
Originally posted by Exami View PostProblem's with banding is that i don't want rims to in weird sizes and if i widen it 1" from back.. offset would gone -1 :E and front offset -5 on front that could be just fine but on back.. that extra 7mm is no near fitting thats why i was thinking to build 3piece..
And also since no one in finland does that.. its BIG problem meaby i need to contact BBS and ask for wider lips
BBS won't have anything wider for the Style 5's because there was never anything wider than an 18X9 so you're kinda out of luck...Eatin' Babies
Originally posted by DaRedRocket View PostAssuming you have 18X9ET24/18X8ET20 adding 1" of lip would make it 18X10ET12ish and 18X9ET8ish. As for not being able to get the lips widened easily near you, if you want wider wheels looks like you'll have to ditch the Style 5's.
but yea meaby i need to start looking for BBS GT:s cause those are 3piece and somewhat more easily widen..
Originally posted by Petis View Postyou should just put the rears up front, and buy entirely new barrels for the 8" from somewhere aftermarket. Then you will only be buting a pair of barrels, thus saving you money.
Originally posted by Morbid View Post18x10 super rs ;-)
