Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Fluid MotorUnion: An Inside Look
    Jun 2009
    Plainfield, IL
    4,575
    Default Fluid MotorUnion: An Inside Look
    You may be reading this website from a place far away from our homestead of Plainfield, Illinois. If you’ve never been by the shop and given a tour, this post is for you. Welcome to the inner workings of Fluid.
    We begin with the point where many visitors and callers to our shop begin - the main office. Here, Marilynn and Sean perform superhuman tricks in order to keep us running at full capacity. If you’ve ever had service done here, or called in and talked to Marilynn, this is where it all goes down. Also pictured is Mark, a man who can do just about anything with a computer, and Diesel, one of the several resident shop pups. Don’t let his small size fool you; he’s got some serious barking skills. The same goes for Diesel.
    From the main office, we’ll walk down two steps into the secondary set of offices, where Andrew (your humble narrator) and Mike Marzano spend a good chunk of their days. AJ and Eastway are also staples of this room, coming in to do some work on SolidWorks or just design work in general — sometimes, a desk is a better place to design than a shop is. For that reason, we’ve got plenty of desk space.
    Walking outside the offices, we enter the service side of the garage. This is the larger portion of the service section, with two lifts and plenty of space for tires, balancers, and just about everything else you’ll encounter in a typical service bay. The one thing we’re lucky enough to have over every other service joint, though, is the talent. OJ, Zach and Keller put in some serious time and serious effort to make things leave this garage much better than when they arrived. For that, they deserve plenty of kudos.
    And here’s a shot of our secondary service bay, with another two lifts.
    From there, we’ll take a quick trip through the pass-through, and onto…
    Luci’s garage. Yes, the man has his own corner to himself, but for a superhero it’s the least we can do. Since he’s in charge of all the painting, his corner also comes with the paint room. Luci has two lifts just for himself, which sometimes seems like it’s not enough for a man with a work ethic that just won’t quit. As for what’s currently inside the paint room, if you’ve been following the blog, you’ll certainly know what we’re up to. We won’t say any more on that subject.
    Now, we have to take a quick trip outside and across the parking lot, where we reach the fabrication garage. What originally started as car storage has since been transformed into a fully-fledged fabrication station with just about everything we need to build just about anything. Most things that are built in fabrication start in Eastway’s corner, with his CNC mill, manual lathe and vibratory finisher, among other industrial equipment. We also received a plasma cutter just today, which has been the object of much affection since its arrival; sadly, it arrived just after the pictures were taken.
    Moving up the ramp from Eastway’s cutting corner, we arrive at the dyno (in the room on the right) and the main event itself, the location where all our fabrication work takes place. All the gorgeous welds you’ll encounter on this website are done in this very room. Next to the dyno you will see our very first project car to receive international renown, Gold Wheels.
    Further into the garage, you’ll encounter most of our other current project vehicles, including AJ’s Fluid Racing Honda CBR1000RR. It looks much better on display here than it does in his garage, that’s for sure. It was apparently quite the tricky piece of maneuvering to ride it from his house to here, but the man is all chutzpah, so everything went off without a hitch. You’ll notice our project SL in the background, as well; more news on that build should be arriving shortly.
    Finally, we reach the last destination at Fluid - the Dyno Lounge. This is our most recent project, and when your narrator says “our,” he really means AJ’s project. What was once again more storage was envisioned by AJ as a place to come and hang out, watch your car get worked on, check out the progress on the dyno, and just relax in general in a building filled with fellow gearheads. The decorations on the wall, some provided by AJ, tell a story about the history of Fluid, parts we’ve made, and generally just help to describe our mantra with building cars and the mindset we all share. If you could have seen what this looked like when it was storage, you’d be rushing up to AJ, shaking his hand and buying him a drink. He’s seriously put an incredible amount of effort into transforming the fab garage (not just the Dyno Lounge, but the entire garage in general) into something we can be proud of, something that everybody can enjoy. Again, kudos to him and to all the Fluid crew for putting in 150% day in and day out. Your humble, anonymous narrator is a mouse amongst men in this company, and once you witness Fluid for yourself and see this dedication firsthand, you’ll truly understand why it sucks to roll hard (but we still do it anyway).
    If you ever feel like swinging through Fluid for whims and giggles, feel free. We’d love to have you.
    www.fluidmotorunion.com
    www.stanceworks.com
    Quote Originally Posted by Oxer
    Jul 2009
    Bay Area, CA
    12,330
    Wow. That is pretty awesome. Love the lounge.
    Quote Originally Posted by Oxer View Post
    Quote Originally Posted by Average_Jerk View Post
    kartikeya Guest
    That is probably the coolest new professional shop I've see thus far.
    shops looks cool, but i have heard some really bad stuff from your shop.
    Jun 2009
    near Cologne, Germany
    5,562
    Awesome. I want to go there just to laze around in your lounge, haha.
    Wow!!! thats badasss, n I live 20min away from u guys n never came to see the shop....:facepalm to me lol....I will defenitly stop by this spring/summer when I'm done with the car
    ///M3 drivers have no friends! -Jeremy Clarkson....
    Aug 2010
    Malinwa
    22,867
    Jul 2010
    Derby, UK
    8,008
    Better than any UK garage I've seen. Think you should expand over here.
  9. #9
    Aug 2009
    MEL Australia
    23,230
    If I come and feed the animals, would the world stop spinning?
    How much rent would I have to pay to live in that lounge area?
    Quote Originally Posted by anth View Post
  10. #10
    Jun 2009
    Plainfield, IL
    4,575
    We feed ourselves pretty well. And by "pretty well," I mean "with shitloads of energy drinks."
    For you, Oxer, we'll cut a deal. Only fifteen bucks. An hour. It's the same rate as a seedy motel, except our couches don't contain stains of dubious origin.
    Quote Originally Posted by Jorge View Post
    Well we're currently working on an outpost in Doha, Qatar, but I don't think that's any closer to you guys. I'll put in a word and see what I can do
    Quote Originally Posted by P78 View Post
    enlightening
    Thanks! But double thanks for putting my antagonistic prose in your signature. I feel like a published writer now, or something.
    Quote Originally Posted by 4rings View Post
    Speaking of antagonistic...
    www.stanceworks.com
  11. #11
    wow, awesome shop. If im ever in the area Im definitely coming to check it out
  12. #12
    Aug 2009
    MEL Australia
    23,230
    I just want to come past and sweep the floors.... Just to be able to say I did it.
  13. #13
    Now that I have seen the insides of your shop, Did the boys in the back ever build a motorcycle engine powered open cockpit car....'cause there is an area there that looks very familiar to a youtube vid out there?
    The only thing not shown here is where the missile launch control area is...looks like you are set to TAKE OVER THE WORLD..........cool.
  14. #14
    Oct 2009
    Dallas, TX
    4,294,967,248
    Get a shop up in Dallas and I'd be there every week.
    Quote Originally Posted by Jesus Christ View Post
    if "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.
    Quote Originally Posted by Jedidiah View Post
    he speaks the truth.. he doesn't even have the -- -- eyes.
  15. #15
    Jun 2009
    Plainfield, IL
    4,575
    Quote Originally Posted by flemcadiddlehopper View Post
    We have not built a motorcycle-engined open cockpit car...but the idea is certainly intriguing.
    Our missile launch control area is actually getting painted right now, elsewise I would have included it in the photoshoot.
    www.stanceworks.com
  16. #16
    Aug 2009
    MEL Australia
    23,230
    Quote Originally Posted by FluidMotorUnion View Post
    I can has wmd? just shoot it over, Ill catch it.
  17. #17
    Jun 2010
    Hilton Head Bluffton, SC
    1,232
    Definitely the cleanest independent shop I have seen in Chicagoland, and I have been to a lot looking for employment.
    One thing though, I see no alignment rack anywhere....
    Strictly Pleasure/Zero Clearance/Stretch Your Legs
    Alex
  18. #18
    Jun 2009
    Plainfield, IL
    4,575
    Quote Originally Posted by NeedingAnAudi View Post
    We actually don't have an alignment rack
    www.stanceworks.com
  19. #19
    Feb 2010
    Brooklyn, NY
    40,592
    Going to have to come see this place in person this summer...
    - Kielan (Key-lin)
  20. #20
    Oct 2009
    no way
    758
    Nice!
    where can I find more pics of the m3 sedan????
    - '89 E30 M-Tech 2
    - '10 TT RS
    - '13 A3 SB
  21. #21
    Apr 2009
    San Jose, CA
    12,902
    Hi Guys
  22. #22
    Aug 2009
    NorCal
    1,398
    Wow very cool place you guys have there.
  23. #23
    My buddy called there asking if you guys redrill wheels and the lady told him, "why would you redrill wheels, thats very dangerous and your wheels can fall off and you can die"
    Really, is that how you guys talk to customers?
  24. #24
    Jan 2011
    Chicago Area
    7
    No. We only talk in rhymes. Especially when it's a life or death situation.
    [/SIGPIC]
  25. #25
    Feb 2010
    Brooklyn, NY
    40,592
    Quote Originally Posted by AJ@Fluid MotorUnion View Post
    - Kielan (Key-lin)
