Aussie Random Thread.
This is a sticky topic.
  • Originally posted by neni View Post
    noiceeeeeeeeee. looks to be in not bad shape either
    thanks man, its not bad, a little rough around the edges but not bad overall
    Originally posted by INVSBL View Post
    wow, you got a white one.
    please make it look good
    does it run?
    also im guessing r31 daily, 180 skids, datsun stance?
    Yeah datsun runs, a little rough on cold start but smoothly once its warmed up
    R31 is gona go once the Datsun is rego'ed
    gona trial fit some wheels onto the datsun to see how they sit, but will be a while before it receives low
    • reckon it needs much for a legit roady?
      • Originally posted by INVSBL View Post
        shouldn't need much, it was last registered in Nov
        needs a heater hose under the dash replaced which i already have a spare for and fix the loose wire on the wiper motors
        the rest should be ok
        i'm also gona replace the ignition barrel and door locks since the barrel is a bit worn and doesn't release the key as smoothly as it should and door locks don't match the ignition barrel key since the car was restored from parts of 2 spare cars
        • roman. love it!
          slap those emtiz on it
          • Originally posted by mohsen View Post
            roman. love it!
            hmm i've seen 16x10 -32 on a Z with flares, so the emitz would actually fit
            but 18s are too big
            • 15's + flares
              • 15's, no flares for now
                • Chasing advice guys,
                  Im after new coilovers for the front, but because im going very low profile tyres, on 14"s i will need the coils go go very low. But i dont understand their measurements that they advertise. For eg, it says -20mm to -120mm is the lowering range, but how will i know how much of a drop it will be from my arch to my wheel hub?
                  Any advice appreciated
                  • the FUCK at rego $671 ownage.
                    - = [ M . I . A | c r e w ] = -
                    Originally posted by TRaNz
                    Its not bags, its a tank for the car that keeps the inside car cabin pressurized and uv rays down to a minimum so that colins skin doesnt react with the outside uv rays. The tank is conected to a powercore with a special generator separate to the cars system. As so im told, it uses a nuclear substance which has been supplied by Moh. The complex design was created for people with special skin conditions like colin. Id say its a good investment for colin.
                    • OMFG Emma Watson <3
                      S I N G L E | W O R K S - Loneliness is a Lifestyle
                      • omg i want a respray on the car
                        • OMG i want to respray all over Emma Watson.
                          omg man...naaaaahhhhhh...dafuq bro...nah thats crossing the line. youre fucked bengfacebengcunt.
                          • Originally posted by USDMem1 View Post
                            cappuccino froth.
                            • i made dem jail bait school girls squeal on my way home after work
                                Originally posted by TRaNz View Post
                                cappuccino froth.
                                i see your ranga and raise you a Mila Kunis
