Audi A4 B7 2.0TQ | Project Déjà-vu
  • #31
    I quickly decided i had to throw the new parts onto the more recent A4. The thing is, that this car, given its age, and mileage, would give me a hard time working on it, mostly due to the road grime and debris. All in all the car was in great shape, never seen and accident of any kind, that is why I bought it in the first place after looking for quite some time for the right one.
    I will guide you through the process of the swap, which took about 12 hours, and did it all by myself. It needs patience, and some good quality beer and music. Other than that it is pretty straight forward if you have basic skills.
    I started by removing the sideskirts first, then the front bumper, then wheels. front wheel arches, and front fenders, and then put everything back together - hopefully.
    Driver Side sideskirt removal
    First you remove this plastic to gain access to the bolts beneath it
    Part 8 by mgpdoc, on Flickr
    Many bolts that need to come off
    Here is what you are left with, once you remove the sideskirt.
    After some degreaser and a lot of time
    Passenger side sideskirt before and after cleaning
    Passenger Sideskirt off
    Then we lift the car on the air to work on front bumper and fenders
    Out came the bumper and the washer fluid
    No going back now
    Passenger side was definitely the hardest one to work on, more things in there.
    Lower fender bolts gave me some trouble due to grime and corrosion not letting the torx bit sit in as it should. Then when it did, this happened.
    Nothing some angle grinder cant fix though
    Instead of this
    To the left, the stock A4 fender - sideskirt support and to the right the Rs4 one which is wider
    Installed in place
    First fender was on
    It was now time to see whether the fender line could at least be put in place although it is to be expected to be smaller than needed
    Yeap, and smaller it was. However it fit in place, and nothing rubbed so it will do until i get the RS4 fender liners - if hopefully they are still in production, fingers crossed.
    Headlight washer system was removed, I always found it useless and also it will interfere with the future IC setup.
    Clean bumper ready to be installed
    However I had to do something about this here which led to washer fluid leaking if not plugged.
    At first i thought of doing another route or something.
    But then I remembered i have some silicone hose plugs, which is a big win especially when you have them in stock and can also choose colour lol.
    There, super clean, and neat
    Bumper and Fenders were, on, time to put the remaining things back on
    This is missing and is on order
    Part 9 by mgpdoc, on Flickr
    Time for the sideskirts which at the rear part were wider due to the rear fenders not being on yet.
    Touching ground and as you can see the car got significantly wider
    As for the rear bumper, I can install it in place, however, the side parts of the bumper stick out too much unless the fenders go in. Pics from my old test fit for reference
    Some random pics of the car, that day
    9 years between these two photos, in the same location
    Part 11 by mgpdoc, on Flickr
    Hope you liked this as much as I did.
    Cheers
    Mike
    • #32
      A nice addition to the man cave is this one
      Keeps the project moving for sure.
      A subtle changeI use to do to my project cars, is all red tails. Here it is mostly red as you can see
      Part 10 by mgpdoc, on Flickr
      So added a strip of red tint film on the lower part. A subtle change but it is there nevertheless.
      Also, for anyone looking to buy a car charger to match the Audi interior light, look no further, i am here for you
      Great, because the blue one from Belkin was bugging me
      Also, these arrived
      Cheers, more to come
      Mike
      • #33
        Always nice to read your treads and posts!! Awesome work as always!
        • #34
          Thanks a lot
          • #35
            So satisfying to watch you swap everything over. Do you have the part number on that omp storage thing? I would love that for the vette to match my seats.
            Insta Mintyhinrichs
            • #36
              First of all thanks a lot, it means a lot, especially coming from you mate. Much appreciated.
              As for the OMP, surely, it is NA/1864/N. I love it, it is classy and does the work nicely.
              • #37
                So, like i said I received these cf mirror caps
                First you remove the glass and then the mirror cap, it is relatively easy in this car
                Then you see a whole lot of dirt.
                Before
                After
                Before
                After
                Then it is reinstalling time
                Some heavy coats of this wax
                Ready
                Cheers
                Mike
                • #38
                  Two more things that were done to the car are about wheels.
                  One for the wheels of the car, which is spacers.
                  To at least temporarily make the car sit nicer.
                  The other, is steering wheel, because as much as I tried, the OEM steering wheel is ugly to say the least. One of the ugliest stock wheels I believe for this brand. Not sure if I will go 8V/TTS/R8 flat bottom steering wheel like my A1 for instance, because I do like the feeling of the one I installed very much. And it will match the future seats I have in stock for this project.
                  So let's see some pic of the process.
                  A/ Spacers.
                  Had some 20mm 5x100 spacers in the garage, and decided to make them also 5x112, and take them down to 15mm for square fitment. Although in the eye, it would need 25mm in the front and 10mm in the back. However do not want different sizes on axles of a 4wd car. That's just me.
                  This is how it was before
                  And after
                  Before
                  After
                  Installed 19mm plastic caps for cleaner look
                  Also bought another of these Audi tools for the caps
                  Washed the wheels
                  Here they are
                  B/ Steering wheel swap
                  And some pics of the exterior of the how the car is sitting on the new setup
                  Cheers
                  • #39
                    Need to update this, to bring it up to the current status of the car as we speak.
                    So, firstly, the drivers door card handle was looking a bit tired from the past, and it had some stickers, plus one of the window switches was broken and those had to be addressed.
                    This is how it was
                    Part 12 by mgpdoc, on Flickr
                    Scratched switch
                    Removed the door card
                    New trim from the dealership
                    New switch set
                    Installed in place
                    Removed and cleaned the door handle from the door card , which is help in place by like 10 billion bolts
                    50:50 shot of before and after
                    Put everything back in place
                    Much better
                    Steering wheel collection going strong
                    Looks ok for now, more on the interior later to follow
                    Now, for the wheels. I wasnt feeling comfortable with the thread engagement of the studs and nuts after the spacers' installation, although it was surely safe, more than 2 thirds of the threads were secured. However I wish I had longer studs.
                    Which, as i found out that day, i did have but had forgotten about them, LoL
                    So, pics of before.
                    50:50 shot
                    The forgotten stud kit
                    Marked them to check if they are spinning
                    All done
                    And plastic caps can also be installed for that cleaner look
                    So that is better and safer at least in my mind.
                    Cheers
                    Mike
                    • #40
                      One day, I was like, f*ck it, let's try the rear bumper, although I know the rear fenders are not on, and nor will be anytime soon, considering the time delay in available appointments/bookings in the shop i am interested in taking this job.
                      Anyway, as I said, it was not something sensible to do, but I did it anyways.
                      Here is how it went.
                      Removed the tailights
                      the amount of dirt i was faced with, was to be expected, however it didnt make me less sad. I had to clean these, because they are potential rust spots if you leave them like that under the seals.
                      Removed the Cobra parktronic that was installed and labelled the wiring and installed rubber grommets in place of the old ones
                      I then cleaned everything as you can guess and then went ahead with the installation of the RS4 bumper.
                      I however had to remove this crash bar as well, to paint it, cause it is visible through the bumper
                      And after
                      Installed in place
                      Fender to bumper mounts are different for the RS4.
                      Removed the old ones, and cleaned underneath
                      Installed the fixings for the bolts
                      Then the mounts, 3 of the 4 bolts given, cause the 4th one, is only available in the RS4 rear fender
                      Also fixed this, because someone had pulled the front part off, now allowing the gas cap door to lock like it should. All fixed now.
                      Part 13 by mgpdoc, on Flickr
                      Time to throw the bumper on
                      Here's how the situation at the back is currently
                      Car is fully driveable, and also in high speeds, zero problem of things breaking from air, etc, they are very solid there cause they are held in place with bolts in the mounts beneath them . However I have to decide what I am gonna do with fenders.
                      They are currently on the other car.
                      Cheers,
                      Mike
                      • #41
                        Honk for more updates
                        Part 14 by mgpdoc, on Flickr
                        So, after the installation of the front RS4 fenders, the fender liners were fitted, although looking a bit sorry for themselves, making the car look like a scrap car or something.
                        Ugly to say the least
                        This was something that couldnt stay like this, obviously even if noone saw it, I knew it was there.
                        Ordered Front Fender RS4 Liners and also some other fixings and bolts, as well as the lower fender liner lip part which is also larger in the RS4. I didnt have these parts in the past cause I didnt intend running fender liners in the other car, at all.
                        Material, surprisingly is carpet here, instead of plastic. Premium parts I guess
                        Also bought a tow hook cover which is different in the Rs4 bumper - didnt know that
                        Part number for whoever is interested in it
                        Out came the wheels
                        And then the regular A4 fenderliners
                        New ones on
                        Proper
                        Much better
                        Also, ordered the rear ones, although rear fenders are not yet on, cause you never know when production will stop these days. Like I said in the previous post maybe, production on certain parts of this car, has stopped.
                        So yeah, gotta stock parts I guess
                        Cheers
                        Mike
                        • #42
                          Cleaning and detailing wise, the only thing left untouched in the car, was the interior's carpet and lower surfaces.
                          The exterior hadnt been polished, but it was waxed and looking decent
                          All in all car was very well cared after, no smoking inside it etc, but still you gotta go the extra mile and deep clean those fibers when u buy a used car, in order to feel like home, and not in somebody else's car. It is what it is.
                          So, despite the 45oC [that is 110-115in F] in my country currently, out came the rear seat bench
                          Front seats next
                          First we did the floormats
                          Koch Polstar, agitate, scrub and pressure wash and then the extractor vacuum
                          We then did the same to the interior carpet. It was a big job, but so well worth it. Massive difference even in car that was cared for. The years of ownership are there, and so is the difference in smell and feeling when opening the door and getting in.
                          Then that was out of the way, there was another thing on the list.
                          If you have noticed my cf parts, hood and trunk, they have Aerocatch Quick release pins and locks installed. In the front, I had initially installed them, cause there was a lot of air coming through and at high speeds the hood was instable and didnt wanna risk it breaking the hood latch and coming towards me. It is not rare that we have seen this happening in cars with cf / light hoods . At the back it was a different case, of removing weight of oem lock mechanism.
                          When I transferred the two parts, in this car, I opted for OEM locking mechanisms and latches, so didnt install the pins. However in the front, when I go above 60mph (100km/h) the hood starts bouncing, and makes me feel unhappy to say the least. So the pins had to be installed again it seems just to be on the safe side.
                          Untitled by mgpdoc, on Flickr
                          Transferred the points to drill like this
                          Some tape from the other car, and marking the hole, and then transferring the tape
                          Drilling
                          Installed the old pins from Aerocatch
                          Worked great
                          Wanted a less racing look, so opted for wrinkle black paint
                          Came out clean
                          Boom ready, and safe
                          Now onto the next update.
                          Teaser
                          • #43
                            So, here is a big update. At least for me.
                            As you might have seen, the rear of the car, was looking a bit weird after the rear RS4 bumper installation. The reason for that, are the stock exhaust tips.
                            It is time we do something for this.
                            So here is how the brainstorming procedure came for the design of the exhaust on this car.
                            In the past, I had two exhaust setups, one was with mufflers on both sides , which was the first setup and looked something like this
                            A420vt Exhaust by mgpdoc, on Flickr
                            And then came the single exit muffler which was more aggressive and I loved it, which was this
                            So this time, I was debating whether I would go dual exit, or single.
                            Let's see what I opted for, although I cannot promise I will not do both. LoL
                            Cat was sure, this was a small diameter and had to go.
                            The inspiration for the muffler fabrication was this custom muffler I found in a Celica GT4 from my country scene.
                            It ticked all the boxes for me. So I gave my order for what we wanted to fabricate, and first thing I received was some photos of the mufflers.
                            Engine side
                            Exit side
                            I tried on some tips that would look nice on an OEM+ car, powedercoated in black. Kind of like the RS4 ones but a bit more aggressive. Dont get me wrong I like these, however they dont match the theme with the cf trunk and the holes, currently.
                            So the plan about the catback was the following.
                            Starting from below the driver, 90mm pipe, going into two 70mm pipes, one v-band clamp in each side, and then going further back, to 2x 90mm
                            straight through mufflers, again with one v-band clamp on each side, before the muffler to be able to remove it for cleaning polishing etc. Also , I wanted the interior passing of the muffler, to be the same diameter a the pipe, and have no difference whatsoever.
                            90mm is 3,5inches for my non metric friends.
                            The shop normally polishes all the exhaust, however I asked them if they can leave the welds unpolished cause I like the tig colours.
                            So, the shop removed the OEM catback, and packed it for home
                            Then started working from scratch.
                            The hard part was the first section, due to the massive diameter difference. However the shop made a really good job here, and it is only temporary as I will do the front section pretty soon.
                            The split starts here
                            Welded
                            Installed in place
                            Despite being so big, the clearance was pretty good very happy with that
                            Moving further towards the back
                            Then , the turn
                            Driver side
                            Time for driver side muffle
                            In the back the v-band is visible
                            Grinded some bolts for maximum space available, cause the muffler body was 180mm which I asked for .
                            First side done
                            Moving on the passenger side
                            Also welded a bracing in the turn of the two rear pipes for extra support in between them, not visible in the photos
                            As for the passenger side muffler, all I can say, is that we finished the exhaust fab at about 18.30 and were aligning tips for about 2 hours. Wasnt before 21.00 that i left the shop. Talk about ocd.
                            But as the owner said, "we will not leave the shop until it is what it should and you are happy". I appreciate that more than I can describe.
                            Some finished photos then
                            And some of the next day in daylight
                            Came out exactly like i planned it, and I couldnt be happier with the looks, and the sound clip it brought in the car. More on that in a photo on the first start after the fab. It made a deep tone, that sounds very serious without drone. Love it.
                            Ofcourse , after the future downpipe fab, and decat status, it will be louder, but we shall see then, when time comes..
                            Hope you like the update, and uploading a sound clip in a minute.
                            • #44
                              Sound clip, although not proper
                              • #45
                                So before the next update, I would like to ask if anyone has tried these vinyl/decal kits for the a/c controls or any other interior buttons for tha matter.
                                These scratches here make me wanna change the whole Ac unit sadly
                                I know that in the end i will do just that, was just hoping has any experience, since I sadly sold my perfectly great looking one from the previous car. Wish I hadnt.
                                In other news installed some caps on the OEM Audi wheels that were installed on the Golf for now, and they dont look so bad. Might even colour match them with the car, and see how they are
                                Aug21 Knob by mgpdoc, on Flickr
                                Installed the quick release i had for the steering wheel
                                On
                                Off
                                Now, for some other changes in the center console.
                                Started with this
                                Started pulling things apart
                                Ashtray leaving the car
                                Removed the assembly and will be keeping only the boot
                                This is going as well as the knob, in perfect condition after all these years
                                This can go back in for now.
                                Boot needed some love
                                But came back like new with this product from Koch
                                So I was left with this
                                Time to cut the upper part for two reasons. One, I wanted to shorten it, to reduce the throw a bit, second, you cannot make threads in the upper part due to the metal being like that. Well, you can, just not so easily.
                                So, let's start cutting after applying some protection for metal chunks
                                Hand cutting took a bit too long
                                So I went to my pneumatic saw
                                Boom, easy
                                Took care of the sharp edges and started with this
                                There we go, M12 ready
                                Not bad for some garage hand tools.
                                Test fitting the custom billet gear knob we made in the lathe some time ago
                                All was great, and will add blue thread locker in the final installation as well.
                                Time to put this in then
                                Fits in OEM locations and sits perfectly
                                Boot installation
                                And then, the whole thing - ignore the splatter of wd40 in the AC unit from when i was making the threads haha
                                I really like how it came out
                                Kevlar by mgpdoc, on Flickr
                                Boom ready for now
                                Till next time ,
                                cheers
                                Mike
